Author Topic: 2013 WSCC AutoSlalom Car Class Info/Questions Thread  (Read 7189 times)
March 14, 2013, 10:43 AM #25
Magner Offline
  • Vehicle: Neons
  • Reputation Power: 72
« Reply #25 on: March 14, 2013, 10:43 AM »
March 14, 2013, 10:44 AM #26
Magner Offline
  • Vehicle: Neons
Originally posted by JosiahP
someone correct me if im wrong, but i believe im in street modified? my car was na from factory but is now turbo charged, im going to be running after market wheels 15-9 (stock is 14-6), after market sway bars, after market steering wheel, and bucket seats
Your 1990 Miata could range from the following classes:
-E-Stock
-STS
-CSP
-SSM
If those are the only mods you have on your car you are in SSM, the turbo kits are only allowed there.
When you register use SSM-S if you have street tires (140 treadwear and above) or SSM-R if you use R-comp tires.
    March 14, 2013, 11:24 AM #27
    JosiahP Offline
    • Real Name: Josiah
    • Vehicle: 1990 mazda miata - 1991 Nissan Skyline GTR
    • JosiahP has no influence.
    ok thanks man!
    Life goes by, how quick? Well it depends on your right foot.
    1990 Turbo Miata aka the money pit/race car
    1990 Miata organ donor - scraped
    1990 Jeep Cherokee 3in lifted with 31" tires
    JP Fabworks
      March 21, 2013, 08:59 AM #28
      reyza Offline
      • Real Name: Rey
      • Vehicle: Honda HRV + Suzuki SV1000S
      • Reputation Power: 20
      • reyza barely matters.reyza barely matters.
      Need help figuring out my class as well
      2010 Genesis Coupe 3.8GT
      Only one's I can see fitting are D Stock and ESP.
      I will likely be swapping the stock suspension with coilovers in spring so I won't be fitted into the stock class. I'll be running stock wheels/tires this year I think.
      Was thinking I could fit into Street Touring but the 3.8 (V6) is not listed there. The 2.0T I believe is.
      In this case am I defaulted to ESP?
      Honda HRV
      Suzuki SV1000S
        March 21, 2013, 12:29 PM #29
        Magner Offline
        • Vehicle: Neons
        Excellent question regarding not seeing the V6 Gen coupe under a Street Touring Class car list.
        If you look at the end of page 184 under the STX listing it says:
        Sedans & Coupes NOC (nonsports-
        car-based; 4-seat
        minimum; 3.1L to 5.1L normally
        aspirated or up to 2.0L forced
        induction)
        NOC= Not otherwise classified
        That being said, if you install coilovers you would be in in STX. If you don't install the coilovers you are in D-Stock (provided the rest of the car is also Stock). FYI in STX your Genesis is allowed a maximum of 265mm wide tires and 9" wide wheels.
        Also a reminder for everyone, if you do not have a valid WSCC membership you will not be able to run a car class. You will be placed in a raw group.
          March 21, 2013, 12:35 PM #30
          My car would be in the same class as Josiah right?
            March 21, 2013, 12:40 PM #31
            Magner Offline
            • Vehicle: Neons
            If you are referring to your turbo Miata yes. With the aftermarket turbo you are automatically kicked out of any Stock, Street Touring or Street Prepared class. It goes straight to Street Modified, provided you follow the other SM rules listed.
              April 07, 2013, 09:04 PM #32
              Coach Offline
              • Vehicle: 1994 Toyota Corolla 20v 4AGE Silvertop
              • Reputation Power: 17
              • Coach has no influence.
              Hey Chris, I just want to make sure I have this right.  The new thread wear number for the RS3's does not exclude the tire from my class SMF ? Just from the street stock ?
              1995 Nissan GT-R33 - sold
                April 07, 2013, 09:19 PM #33
                Magner Offline
                • Vehicle: Neons
                No not at all. The rules currently state any  tire with a treadwear rating of 140 or higher is considered a "street tire".
                The Hankook Rs3 rating is going from 140 to 200. You're good to go for SMF-S. :) If you had tire with a rating under 140 you would be in SMF-R.
                Sent from my SGH-I747M using Tapatalk 2
                Last Edit: April 07, 2013, 09:21 PM by Magner
                  April 07, 2013, 09:21 PM #34
                  Coach Offline
                  Thanks
                    April 11, 2013, 09:39 AM #35
                    Magner Offline
                    • Vehicle: Neons
                    Here are some common questions for modifications in Stock Class:
                    What you can do in Stock Class
                    Cat back exhaust
                    ONE sway bar upgrade: front OR rear but not both
                    Shift knob
                    Any drop in air filter
                    Any Tire above 140TW
                    Wheels as long as they are the exact same size as OEM on the car. (offset can be +-6.35mm)
                    Any shock absorber as long as it is a direct replacement for the car.
                    What you CAN'T modify in Stock Class:
                    Can't add Short shifters
                    Can't add an aftermarket intake system like a CAI
                    Can't instal aftermarket suspension bushings that offer a performance advantage over the OEM. Ex polyurethane replacements for OEM rubber bushings
                    Can't add aftermarket motor mounts that are stiffer than stock or motor mount inserts
                    Can't add shifter bushings or short shifters.
                    Can't add any aftermarket suspension springs
                    Any do any ECU tuning; no chips, performance reflashes or plug in apps etc
                      April 11, 2013, 10:13 AM #36
                      rusoman Offline
                      • rusoman has no influence.
                      how about carbon fiber hood, trunk, aftermarket fender and racing seats in a stock car?
                        April 11, 2013, 10:41 AM #37
                        Magner Offline
                        • Vehicle: Neons
                        None of the items you listed fit within the rule set of stock.  If you go back to the first page you can determine what class those parts place you in.
                          April 11, 2013, 12:23 PM #38
                          Just curious, what class would result from directly upping the boost level in a vehicle that has forced induction from the factory?
                            April 11, 2013, 12:42 PM #39
                            Magner Offline
                            • Vehicle: Neons
                            Increase the boost level on a car that came from the factory with a turbo or supercharger would place you in Street Prepared (SP). Stock and Street Touring (ST) classes do not allow an increase in boost levels.
                              April 11, 2013, 01:10 PM #40
                              • Reputation Power: 194
                              April 11, 2013, 11:15 PM #41
                              rusoman Offline
                              I don't see those mods I mentioned in first page.
                                April 12, 2013, 01:20 PM #42
                                Magner Offline
                                • Vehicle: Neons
                                If you have a car with those modifications please add the year, make and model along with any other mods it might have. I'll help you class it in this thread.
                                  April 13, 2013, 05:57 PM #43
                                  rusoman Offline
                                  04 s2000
                                    April 13, 2013, 07:27 PM #44
                                    Magner Offline
                                    • Vehicle: Neons
                                    It's a 100% stock 2004 Honda S2000 with a carbon fiber hood, truck, racing seat, aftermarket fenders and no other modifications? Please provide all modification in order to be classed correctly.
                                    All 00-09 Honda S2000s will fall into one of the following classes:
                                    B-Stock
                                    STR (Street Touring Roadster)
                                    BSP (B- Street Prepared)
                                    SSM (Super Street Modified)
                                    FP (F-Prepared)
                                    Racing seats are allowed in Street Touring (ST) provided they weight more than 25lbs). However Hoods fenders and trunks only become legal in Street Modified. Therefore with your list of modification you would be in SSM.
                                    You never mentioned any information on your fenders, I'm going to assume these are bolt in replacements for the front only. If you had to cut out and replacing the original rear fenders on the S2000 you would be placed in the Prepared category.
                                      April 13, 2013, 08:53 PM #45
                                      rusoman Offline
                                      yea they're bolt on fenders, racing seats for both driver and passenger, slotted front rotor same size as stock, catback exhaust and front lip
                                        April 14, 2013, 01:45 PM #46
                                        Krank Offline
                                        • Real Name: Jim
                                        • Vehicle: '11 WRX / '05 Saabaru
                                        • Krank has no influence.
                                        Cat back exhaust
                                        Shift knob
                                        "Any tire above 140 tread wear" - as long as it fits the stock rim size and the wheel opening with out modifications (no fender rolling)
                                        "Any shock absorber as long as it is a direct replacement for the car." - may be an adjustable shock with only one a maximum of two adjustments
                                        Last Edit: April 14, 2013, 05:28 PM by Krank
                                          April 14, 2013, 02:04 PM #47
                                          Magner Offline
                                          • Vehicle: Neons
                                          Originally posted by Krank
                                          "Any shock absorber as long as it is a direct replacement for the car." - may be an adjustable shock with only one adjustment (example - knoi yellows - rebound adjustment only)
                                          Sorry this is is incorrect,
                                          The 2013 rules state:
                                          13.5.A.1
                                          No more than 2 separate external shock damping adjustment controls
                                          are allowed
                                          Double adjustable shocks are allowed in stock classes.
                                            April 14, 2013, 05:26 PM #48
                                            Krank Offline
                                            • Real Name: Jim
                                            Too early on a Sunday morn ... Just back to check and to change my post.  ;)   Point being the shocks can be adjustable vs. non adjustable stock provided they are the correct fitment for the car they are installed on.
                                              April 19, 2013, 08:34 PM #49
                                              Magner Offline
                                              • Vehicle: Neons
                                              Bump, made some changes in the original posts:
                                              -RAW class no longer exists. If you do not sign up for a car class you will be marked as "Not Yet Classed" (NYC). A reminder, if you don't have a WSCC membership you cannot sign up for a car class, you are limited to NYC.
                                              -All JDM/imported cars are legal for Street Modified, provided the car meets all the rules set in Street Modified (page 107). If you don't meet the Street Modified rules sign up for E-Mod. No JDM/RHD/import is legal for Stock, Street Touring, Prepared or Street Prepared.
                                              How to find your correct Street Modified Class:
                                              Any FWD= SMF
                                              Any car that was originally built as a 2 seater = SSM
                                              Anything else = SM
                                              Last Edit: April 19, 2013, 08:46 PM by Magner
                                                « Reply #49 on: April 19, 2013, 08:34 PM »
