Author Topic: Password JDM Rear Toe Links,Fix those rear toe issues!  (Read 556 times)
January 23, 2013, 10:03 AM #0
optionplus Offline
pwlogo by Option Plus, on Flickr
PasswordJdmToe by Option Plus, on Flickr
Modifying suspension for most people usually starts and stops with lowering a car using springs or coilovers… And that's where the problems begin. Changing the ride height on a car changes everything else. Toe settings and camber angles goes to **** and always resulting in a poor drivability. Having the correct suspension setup involves more than just ride height, it always requires having the corrected camber angles, and proper toe settings as well. This is always overlooked all because the way people seem to test the drivability of a car is to drive it straight. By lowering a car equally on both sides, you will always create an even toe-in or toe-out condition. Your car will drive straight since the toe is either pulling or pushing evenly, and unless you know what to feel for, it will also drive like ****. Having the toe settings off will create a unwanted over/under steer condition. The Password:JDM Ultimate Rear Toe Links will help you fix this problem and also eliminate the sloppy rubber bushings in the process.
PasswordJDM by Option Plus, on Flickr
The new patent pending Password:JDM Ultimate Rear Toe Links allows for quick and easy adjustment of any rear toe problems your car might have. Just like the Ultimate Rear Camber Links, the Password:JDM Ultimate Rear Toe Links uses a track-grade, self-lubricating Teflon lined spherical rod ends with zero maintenance that provides superior performance over polyurethane and rubber bushings. Coupled with these rodents are CNC machined stainless steel misalignment spacers that makes it all come together. There's nothing to bind, deflect or blow out at either end so you can be sure that "the position for the win" stays that way... Well, at least until you monkey with the set-up again. Being able to fine tune your suspension needs makes this a required part of your arsenal and will save you money from replacing prematurely worn out tires, make you safer and make you faster. You won't find a Rear Toe Link with a better design and more adjustability than these. Like all of our other suspension products, we designed these to be better than anything else on the market… that’s why they are called the Password:JDM Ultimate Rear Toe Links!
optionplus~dealertop by Option Plus, on Flickr
Option Plus Hours and Email
info@optionplus.ca
Mon-Fri 9-7pm
Sat 12-5pm
Sunday Closed
    « on: January 23, 2013, 10:03 AM »
