Author Topic: ICHIBA Hubcentric Wheel Spacers In Stock  (Read 893 times)
January 24, 2013, 09:31 AM #0
optionplus Offline
ICHIBA wheel spacers are made from Aluminum/Magnesium alloy. They are incredibly strong and very lightweight. Each wheel spacers are two pieces design with pressed studs. Now it's time to bolt-on without any swap studs hassles. These are hubcentric spacers that is specifically made to each vehicle; will fitted on your vehicle's original hub perfectly without any gap. Wheel spacers move the wheel out from the hub, effectively widening the stance of the vehicle and lowering its roll center. This simple modification increases lateral stability, which in turn provides improved handling & greater safety.
ICHIBA by Option Plus, on Flickr
The widest point of your tire and wheel combination is usually the outside diameter of the tire sidewall. Using a ruler with the straight edge flush with the face of the tire, measure the gap between the outer face of the tire to the inside lip of the fender as shown in the diagram. This will determine the thickness of the spacer you will need.
Spacer Sizes: 5mm, 8mm, 10mm, 12mm, 15mm, 20mm, 25mm, 30mm, 38mm, 50mm.
optionplus~dealertop by Option Plus, on Flickr
Option Plus Hours and Email
info@optionplus.ca
Mon-Fri 9-7pm
Sat 12-5pm
Sunday Closed
    « on: January 24, 2013, 09:31 AM »
    January 24, 2013, 09:56 AM #1
    ChezoR33 Offline
    • ChezoR33 has no influence.
    Price?
    (OO\SKYLINE/OO) Dude your beds a car! yeah but its a f@#$ing sweet car!
      January 24, 2013, 10:03 AM #2
      optionplus Offline
      PM SENT
        April 01, 2013, 01:47 PM #3
        price for 10 mm for 09 lancer ralliart plz
          April 01, 2013, 02:37 PM #4
          Shier Offline
          • Real Name: Greg
          • Reputation Power: 53
          How much for a pair of 20mm and 25mm for a genesis coupe
            April 01, 2013, 04:09 PM #5
            optionplus Offline
            PM SENT
              « Reply #5 on: April 01, 2013, 04:09 PM »
