Author Topic: FS: Misc. Honda/Acura parts and accessories for Civic and Integra(with pics.)  (Read 4592 times)
February 26, 2013, 09:49 PM #0
bonspeed Offline
  • Reputation Power: 20
  • bonspeed barely matters.bonspeed barely matters.
For Sale:
- '96-'00 Civic hatchback OEM EK9 power folding mirrors, will fit on '96-'00 civic coupe's as well. does not come with switch and relay, mirrors only. - SOLD!
_DSC0429 by bonspeed07, on Flickr
- NGK spark plug wire for b18a/b b20 engine would work with b16 and gsr engines too - $60
- Brand new oem replacement 2007-2009 Honda CR-V foglight kit, comes with wiring harness, relay, bulbs, plastic ring and switch. - SOLD!
- 1989 Toyota Camry power window master switch - $5
- Alpine CD changer off my DX coupe, missing the CD slot - $5
- OBD0 B16 intake manifold with injectors, fuel rail, fuel pressure regulator, throttle body, harness(missing vtec pressure switch, vtec solenoid, knock sensor wires), no IAT sensor and IACV sensor - SOLD!
- '92-'95 Civic hatchback/coupe OEM side skirt - $30
- '96-'00 Civic sedan door hinges(front driver side) good condition, not sure if will fit hatchbacks and coupes - $ 5
- Honda D series manual transmission starter - $35
- '96-'00 Civic D series rear transmission bracket, a/c compressor bracket, front transmission bracket - all for $40 obo
- '96-'00 Civic front driver side door glass - $10
- '90-'93 Acura Integra interior pieces, tail light cover, rear view mirror, fan blower knob, driver side front speaker cover, rear center lap belt, left and right radiator stay, - $5
- '90-'93 Acura Integra OEM airbox - $10
- D16y7 manual transmission ECU(P2E) - $25
- Brand new B series cable type release bearing - $30
- '96-'98 Civic Si manual transmission ECU OBD2A(P2P) -  $50
- '96-'00 Civic ABS control unit - $40
- '96-'00 Civic/CRV/Prelude JDM side marker w/sockets and bulbs(3 sets available) - SOLD!
_DSC8056 by bonspeed07, on Flickr
_DSC8055 by bonspeed07, on Flickr
- Tenzo R oil pressure gauge - SOLD!
- 1" brake master cylinder with double diaphragm booster from a JDM ITR, will bolt directly onto '92-'95 Civic's and '94-'97 Integra's. Can be fitted to '96-'00 Civic's and '98-'01 Integra's too but you'll have to bend the brake lines a bit. - $100 or trade with something interesting of equal value - SOLD!
- EX41 Tilt plate holder(plastic) 2 available - $30 each
_DSC9935 by bonspeed07, on Flickr
- set of '94-'01 Acura Integra front and rear calipers with brake pads and rotors - $180 firm
_DSC0755 by bonspeed07, on Flickr
or $230 with 15/16 master cylinder and proportioning valve
or $240 with 1" master cylinder and proportioning valve
if sold separately:
- '94-'01 Acura Integra front calipers(17CL14VN) also fits '92-'00 Civic EX/Si/SiR - $60/pair(brake pads free)
- '94-'01 Acura Integra rear calipers(7CLP13S) also fits '92-'95 Civic Si and '99-'00 Civic SiR - $60/pair(brake pads free) - SOLD!
- '94-'01 Acura Integra front rotors, also fits '88-'00 Civic EX/Si, '99-'00 Civic SiR- $50/pair
- '94-'01 Acura Integra rear rotors(drilled and slotted)not sure what brand, also fits '92-'95 Civic Si and '99-'00 Civic SiR - $50/pair - SOLD!
- '94-'01 Acura Integra 15/16 brake master cylinder(abs) also fits '96-'00 Civic all models - $30(2 available)
_DSC0759 by bonspeed07, on Flickr
_DSC0758 by bonspeed07, on Flickr
_DSC0760 by bonspeed07, on Flickr
_DSC0761 by bonspeed07, on Flickr
- '97-'02 Honda Accord 1" brake master cylinder, also fits '98-'01 Acura Integra and '96-'00 Civic with a little modification on the brake line - $40
_DSC0756 by bonspeed07, on Flickr
_DSC0757 by bonspeed07, on Flickr
- '98-'01 Acura Integra 40/40 proportioning valve(non abs) also fits '96-'00 Civic all models - $40 - SOLD!
_DSC0762 by bonspeed07, on Flickr
- '96-'98 Civic JDM CTR EK9 OEM grill - $180
_DSC0901 by bonspeed07, on Flickr
_DSC0903 by bonspeed07, on Flickr
- '96-'98 Civic JDM EK4 SiR headlights, does not come with headlight bulbs but comes with city lights sockets and turn signal sockets, no broken/cracked tabs. passenger side has a small spider web crack on the upper portion of the chrome housing(pictured) but doesn't affect lighting and not really noticeable unless you look close, driver side is showing some haze on the upper part of the lense(also pictured) but other than that the headlights are in good condition - $180
_DSC0911 by bonspeed07, on Flickr
_DSC0914 by bonspeed07, on Flickr
_DSC0915 by bonspeed07, on Flickr
_DSC0916 by bonspeed07, on Flickr
_DSC0917 by bonspeed07, on Flickr
_DSC0925 by bonspeed07, on Flickr
_DSC0927 by bonspeed07, on Flickr
_DSC0931 by bonspeed07, on Flickr
- '96-'00 Civic/CRV/Prelude clear side marker - $40 - SOLD!
_DSC0909 by bonspeed07, on Flickr
- '96-'00 Civic sedan/hatchback/coupe radiator support - $120(what you see is what you get) - SOLD!
_DSC0933 by bonspeed07, on Flickr
- '96-'98 Civic sedan/hatchback/coupe front reinforcement bar with headlight/bumper spacer - $100
_DSC0934 by bonspeed07, on Flickr
- OEM replacement front bumper, fits '96-'98 hatchback/sedan/coupe. paint has chips here and there from highway driving and when hitting cones at autox but no cracks and tabs are good on each side. - $70
_DSC1700 by bonspeed07, on Flickr
- CTR EK9 style grill, fits '96-'98 civic hatchback/sedan/coupe - $60
_DSC1703 by bonspeed07, on Flickr
_DSC1705 by bonspeed07, on Flickr
- CTR EK9 style front lip('98spec) fits '96-'98 civic hatchback/sedan/coupe(polyurethane). some paint chips from hitting cones at autox and duct tape to prevent the paint from flaking  - $80
_DSC1702 by bonspeed07, on Flickr
- '96-'00 Civic HATCHBACK OEM honda rear bumper - $80
_DSC1698 by bonspeed07, on Flickr
If your interested call or text me @ 204-898-0502 or send me a pm here
Thanks!
Last Edit: October 20, 2015, 11:30 PM by bonspeed
REV HARD... or DON'T REV AT ALL!!!
||Mike Woo Racing!!||
: learn to drive before you start spending money and turning wrenches; it's the best investment you can make.
checkout my build thread
    February 27, 2013, 12:14 AM #1
    February 27, 2013, 10:28 PM #2
    bonspeed Offline
    Update:
    - Tilt plate holder - SOLD! 1 more available
    - '92-'95 Civic/'94-'01 Integra JDM flat side marker w/sockets and bulbs - SOLD!
    For for wicked for sale thread. Take notes people.
    haha thanks! oh and on your sig.
    ||Mike Woo Racing!!||
      March 04, 2013, 09:39 PM #3
      bonspeed Offline
      bump!
      updated 1st post
      ||Mike Woo Racing!!||
        March 06, 2013, 03:26 PM #4
        Magner Offline
        • Vehicle: Neons
        Free bump for an honest seller.
          March 06, 2013, 03:39 PM #5
          dolan Offline
          • Real Name: Dyllan
          • Vehicle: 2000 civic si
          • Reputation Power: 0
          • dolan is looked down upon.
          Von when can I get that window from u and is it for a coupe
          Sent from my SGH-I747M using Tapatalk 2
          Dyllan Angelkovski (aka) Dyllan Africa
          [Mar 27 22:16:27] Uncle Hugh Myron:i bet PEAVEY MART NOW OPEN has it
            March 27, 2013, 08:26 PM #6
            bonspeed Offline
            thanks chris!
            sorry for the uber late reply dyllan, the window came off an ek sedan
            and updated 1st post again.
            ||Mike Woo Racing!!||
              March 27, 2013, 09:40 PM #7
              dolan Offline
              • Real Name: Dyllan
              Sll good than nvm on it bumb though
                March 29, 2013, 01:07 PM #8
                still have the tires?
                  March 29, 2013, 08:11 PM #9
                  bonspeed Offline
                  Yeah I still have it but its pending to someone till sunday
                  ||Mike Woo Racing!!||
                    March 31, 2013, 10:20 PM #10
                    bonspeed Offline
                    Update:
                    - 2 pieces 195/55/15 Michelin Pilot exalto a/s about 60-70% thread - SOLD! Thanks ACiFiC
                    ||Mike Woo Racing!!||
                      April 06, 2013, 07:37 PM #11
                      bonspeed Offline
                      update:
                      - B18a1 post mount bracket - SOLD!
                      - '96-'98 Civic Si manual transmission ECU OBD2A(P2P) - SOLD!
                      - Tilt plate holder(1 available) - ALL SOLD!
                      ||Mike Woo Racing!!||
                        December 05, 2013, 11:24 PM #12
                        bonspeed Offline
                        bumping this ad, added up some parts and updated as well
                        ||Mike Woo Racing!!||
                          March 24, 2014, 11:03 PM #13
                          bonspeed Offline
                          thread bump, spring cleaning time!
                          ||Mike Woo Racing!!||
                            July 13, 2014, 02:15 AM #14
                            bonspeed Offline
                            ad updated, bump!
                            ||Mike Woo Racing!!||
                              August 05, 2014, 10:22 PM #15
                              bonspeed Offline
                              bump! new item added.
                              ||Mike Woo Racing!!||
                                September 09, 2014, 10:50 PM #16
                                bonspeed Offline
                                update
                                ||Mike Woo Racing!!||
                                  May 17, 2015, 04:26 PM #17
                                  bonspeed Offline
                                  bump!
                                  ad updated
                                  ||Mike Woo Racing!!||
                                    May 17, 2015, 10:03 PM #18
                                    bonspeed Offline
                                    update:
                                    ||Mike Woo Racing!!||
                                      May 18, 2015, 11:13 PM #19
                                      bonspeed Offline
                                      update:
                                      ||Mike Woo Racing!!||
                                        May 24, 2015, 10:41 PM #20
                                        bonspeed Offline
                                        update:
                                        - '98-'01 Acura Integra 40/40 proportioning valve(non abs) also fits '96-'00 Civic all models - SOLD!
                                        ||Mike Woo Racing!!||
                                          June 06, 2015, 04:45 PM #21
                                          bonspeed Offline
                                          bump!
                                           added some parts
                                          ||Mike Woo Racing!!||
                                            June 14, 2015, 10:55 PM #22
                                            bonspeed Offline
                                            update:
                                            - '96-'00 Civic/CRV/Prelude clear side marker -SOLD!
                                            added more parts too!
                                            ||Mike Woo Racing!!||
                                              October 20, 2015, 11:31 PM #23
                                              bonspeed Offline
                                              bump!
                                              ad updated with new parts and new price
                                              ||Mike Woo Racing!!||
