Author Topic: Type One Racing (T1R) Coilover 06+Civic  (Read 565 times)
March 21, 2013, 11:36 AM #0
optionplus Offline
TypeOneRacing by Option Plus, on Flickr
T1R B52 Damper kit - Honda Civic 06-08 FG2 FA5
Comfort and Performance normally is not a combination you can find from most of the suspension available the market. T1R offers 46mm piston MONOTUBE design for super wide range dampening ranges for street and track. 36 way compression and rebound (single)adjustable. Ride height and stroke adjustable for extreme lowering. CNC machined chromoly steel body with all CNC machined forged aluminum perches and adjust brackets for durability and quality assurance.
Springs are made with cold forming process, extreme high quality and durable. We offer F.8k R.6k for best streetable and weekend tracking necessity.
Front camber adjusting uppermounts are also equipped for negative camber adjustments up to -5 degrees.
T1RCOILS by Option Plus, on Flickr
All kits come with adjustable wrenches and necessity hardware for installation.
-Aluminum Body
-Mono-tube construction
-Dual Adjustment (Pre-tension and ride-height)
-36 step Compression/Rebound Adjustable (Single adjustment)
-Pillow Ball front mount, uses OE rear top mount
-10 kg/mm (f) 8 kg/mm Rear Spring rates
OptionPlus by Option Plus, on Flickr
Option Plus Hours and Email
info@optionplus.ca
Mon-Fri 9-7pm
Sat 12-5pm
Sunday Closed
    « on: March 21, 2013, 11:36 AM »
