Author Topic: Blackworks Racing Products  (Read 981 times)
April 10, 2013, 12:14 PM #0
optionplus Offline
Blackworks by Option Plus, on Flickr
Lots Of Blackworks Racing Products In Stock!
These BlackWorks Battery Tie Downs are CAD designed constructed of high quality 6061 CNC Machined Billet aluminum.They are anodized to give an amazing look that will last for years. The BWR Battery Tie Down works with your stock mounting bolts and OEM or aftermarket batteries. Each one has a laser engraved logo, and are individually laser serialized number to guarantee authenticity
We are proud to announce the new Black Works Racing Oil Block Adapters. The come in 4 different colours: gold, black, polished and red.
WASHER BOLT KIT (5 Washers, 5 Bolts)
Blackworks Racing Billet Rear Tow Hooks are designed using the latest and state of the art CAD design programs in the industry. Our Tow hooks are manufactured in the USA and made from high quality AL6061-T6 billet aluminum. Laser engraved logo, also includes laser engraved individual serialized number to guarantee authenticity. Includes necessary hardware for installation.
BlackWorks Racing rear adjustable camber kits are manufactured from forged AL7075. Each of our kit's use vulcanized rubber bushings. BlackWorks Racing rear camber kits are laser etched, and anodized in two colors (bronze, and Black)
BlackWorks Racing Rear upper camber arms replace the factory steal upper arms, these are adjustable up to +/- 5 degrees. Using our rear camber arms will allow you to adjust positive and or negative camber in your daily driver or your weekend warrior. By having correct camber will improve tire wear, handling, and safety while at the same time have a lighter and improved cleaner look.
WARRANTY:
BlackWorks Racing (BWR) offers a limited 1yr. warranty on all of our camber kits.
Features
•BlackWorks Racing (BWR) Race Breather Box Kit is designed to replace the
• factory PCV system and vent to atmosphere. Our cans are CAD designed
•and CNC Press Punched using the latest state of the art technology. The
•-10 Plugs are welded from the inside to top off that ultra clean look.
•This kit includes all fittings, plugs, clamps, hose and catch can, Ideal
• for all turbo setups. (Note this kit is designed to mount in the
•factory battery tray for a simple clean install on vehicles 92-00 Civic
•and 94-01 Integra)
Kit Includes
                - 1x AL6061 CNC Press Punched Catch Can
                - 2x K&N Filters
                - 6x Black -10AN Straight Fittings
                - 2x Black -10AN 45 Degree Fittings
                - 2x Block Plugs (CNC M28 to -10 Adapter)
                -10AN Black Braded Lines (10 Feet)
                - 1x Black BWR Billet Battery Tie Down
                - Includes 2 -10 Weld On Fittings for your valve cover ventilation lines
-Lifetime Warranty
BlackWorks 2" extended open end forged AL7075 magnesium alloy lug nuts are for serious racers, and or your extreme weekend enthusiasts. These are available in 12x1.5 thread pitch pattern. All lug nuts are hard anodized for strength and durability. For maximum results use our BlackWorks Extended Wheels Studs.
Blackworks shift knobs are made from high quality stainless steel with a titanium finish.
BlackWorks Rear Lower Control Arms have been redesigned for the final and last time!!! With our high demand on our subframe Braces and customer's input asking for a close match we have came out with this design. Blackworks lower control arms now offer 3 mounting points for sway bar's so the consumer can fine tune their suspension to their liking. Offering a non sealed polyurethane bushing gives our control arms better pivoting points with out bushing tear. Switching from a rubber sealed bushing to a polyurethane bushing helps provide a stiffer suspension. BlackWorks Offers a lifetime Warranty on our Lower Control Arms reason behind that we manufacture them not out source them. We know what goes into our products and stand behind them fully and 100%.
OptionPlus by Option Plus, on Flickr
Option Plus
23-584 Pembina Hwy
Winnipeg, Manitoba
R3M 3X7
info@optionplus.ca
(P)204-415-4276
(F)204-415-4042
    « on: April 10, 2013, 12:14 PM »
