Author Topic: My Aspen White 08 STI  (Read 10132 times)
May 03, 2013, 10:49 PM #25
Adomp Offline
  • Real Name: Adom
  • Vehicle: BMW E36
  • Adomp is working their way up.Adomp is working their way up.Adomp is working their way up.
Originally posted by BoostAddict
I filled her up and started the journey home. Those 2 hours were pure bliss.
eeeeeeeeee, I see what you did thurrr.  Jk, car looks amazing. Super jealous.
[May 03 15:40:09] Uncle Hugh Myron:when 10 asians come at me with weapons i just get on my knees and start sucking their dicks
[Dec 10 16:08:15] Shaun:if u put adom in a cold tub it turns into a hot tub
[Dec 18 12:21:50] Nirusan:ya right
[Dec 18 12:21:49] Nirusan:lmao adomp coming to a tti  event
    « Reply #25 on: May 03, 2013, 10:49 PM »
    May 31, 2013, 12:38 PM #26
    Josia Offline
    • Real Name: Josia Toews
    • Vehicle: 08 GTI, 99 Civic Type R
    • Reputation Power: 34
    • Josia is working their way up.Josia is working their way up.Josia is working their way up.
    Small update:
    I took off the Project Kics spacers and put on the cheaper Ichiba spacers. The Project Kics were not hubcentric and the vibrations were really starting to annoy me. The Ichiba spacers came with hubcentric rings that fit just right and the car drives a million times nicer. Lesson learned.
    [Feb 22 17:00:55] Shaun:i hate chatbox
      May 31, 2013, 03:16 PM #27
      xrdriver Offline
      • Vehicle: '15 STi &'10 STi
      • xrdriver has no influence.
      Did you install the extended studs yet?  I am thinking of getting some and I wondered who installed yours.
      Have you thought about getting a performance alignment?  It looks like you are on a stock alignment (no camber) and you might benefit from some negative camber in the front.  I was able to get -1.5 deg on the stock camber bolts.
        May 31, 2013, 05:58 PM #28
        Josia Offline
        I had to install the extended studs to run these wheels. The stock studs are far too short even with only a 10mm spacer.
        I pressed them in myself. I will be ordering coilovers soon and will get everything properly aligned then.
          August 19, 2013, 12:54 PM #29
          Josia Offline
          Small Update:
          The car has started making loud clicking noises when turning at slow speeds in parking lots and such. Took a look underneath and saw one of my ball joints was bad but this was not the source of the clicking noise. The inner CV Joints are bad so I'll be sending the half shafts away to be rebuilt at some point this month. This will leave me without a car to drive for a few weeks and that makes me a sad panda.
            August 19, 2013, 01:00 PM #30
            Wouldn't it be easier to just replace the axle?
              August 19, 2013, 01:12 PM #31
              Josia Offline
              Yes but since it's only the inner joint causing the issue it can be rebuilt for less than the cost of a new axle.
                September 30, 2013, 03:18 PM #32
                Josia Offline
                The rebuilt axles have been installed for 2 weeks now and the car feels great. The new ball joints probably helped too. She's almost at 45,000 miles now so I'm trying to decide if I should put money into the suspension or if I should be saving for a new shortblock just in case. Might have to get a leakdown and compression test before winter to see how she's doing.
                  January 25, 2014, 06:01 PM #33
                  Josia Offline
                  Small update.
                  Did an oil change today and figured I'd take my intercooler off to see if there was any oil in there. Thankfully it was very clean.
                  I did notice something rather odd though.
                  Pretty sure the Pitch Stop mount shouldn't look like that. Ordered a Kartboy unit from Touge Tuning right after I saw this.
                    January 25, 2014, 06:32 PM #34
                    TorqueThrust Offline
                    • Real Name: Alex
                    • TorqueThrust has no influence.
                    damn plastic crap
                      January 25, 2014, 07:13 PM #35
                      January 25, 2014, 07:25 PM #36
                      John Offline
                      • Real Name: John
                      • Vehicle: 04 civic, 09 STi
                      • Reputation Power: 101
                      • John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.John has an aura about them.
                      Air conditioner line bracket?
                      pitch stop mount. under the AC line bracket
                      subies ftw!
                      [Dec 04 11:42:55] Shaun:i tried using nav to get to dan's logic but i got lost
                      [Dec 05 21:53:59] Uncle Hugh Myron:I dunno but an easy way to kill Dan would be shutting down mcdonalds for 24 hours
                        January 25, 2014, 09:57 PM #37
                        torq Offline
                        • Real Name: Graham
                        • Vehicle: '10 mazdaspeed3
                        • torq has no influence.
                        Forgive me, is a pitch stop mount equivalent to my rear motor mount to stop your engine from moving forward/backward around an axis (pitch). If so, why is it made of plastic?
                        Last Edit: January 25, 2014, 09:58 PM by torq
                          January 25, 2014, 10:04 PM #38
                          Stefan Offline
                          • Real Name: Stefan
                          • Vehicle: 2004 WRX wagon
                          • Reputation Power: 48
                          • Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...
                          Yes that's what it is. This is why it's a popular mod for Subarus. Ordered a forged one earlier today.
                          build it - race it -  break it - do it all over
                            March 02, 2014, 11:47 AM #39
                            Josia Offline
                            Small update. Bought a set of used Volk CE28n Time Attack wheels in 18x8.5. They need a lot of cleaning and have some curb rash. I'm planning on powdercoating them white and see if I can pull off the white on white look this year.
                              March 02, 2014, 12:07 PM #40
                              White on white will look awesome! Must be nice to have paint without pearl.
                                March 02, 2014, 12:11 PM #41
                                Nismoline Offline
                                • Real Name: travis
                                • Vehicle: R32 GTR
                                • Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.Nismoline has an aura about them.
                                that will looks awesome, congrats on the purchase!
                                Jdm parking fo life!
                                #driven2016
                                  May 12, 2014, 03:23 PM #42
                                  Josia Offline
                                  So last Friday I decided to install some of the stuff I had sitting around my basement. Unfortunately all the pictures I took somehow didn't save. So thanks iPhone. I guess I'll try to make this as interesting as I can without pictures.
                                  First order of business was removing the front swaybar and endlinks. I was told the endlinks would probably only come off with some help from an angle grinder. Everyone that told me this was 100% correct. After the original swaybar and endlinks were out I installed my new 24mm Whiteline swaybar and Kartboy endlinks. The endlinks came with a bunch of washers and spacers which I had to use to get them as vertical as possible.
                                  Next I installed my 22mm Whiteline swaybar in the back. Thanks to Tony's advice the removal of the original swaybar and endlinks was a piece of cake. The lower control arm bolts were on there pretty tight and there was no way I could fit my breaker bar back there with the exhaust so that had to come off. Whatever no big deal.
                                  Next on the list were the Feal Coilovers. Pretty simple install. Take old struts out, put new shiny coilovers in. The damping is set to full soft on all four corners right now. I still have to lower the front a little bit to match the rear but that should get done today. Need to schedule a wheel alignment after that's done.
                                  This all took me and my dad about 4 hours. I took the car for a short drive after and was very impressed. It feels so planted around corners now and there is absolutely no body roll. Very pleased with the final result. I will take some pictures of the final result once the car is clean and all this rain stops.
                                    May 12, 2014, 05:14 PM #43
                                    4 hours?! Damn you guys work quick
                                      May 13, 2014, 01:52 PM #44
                                      projectk20 Offline
                                      • Real Name: T.J
                                      • Vehicle: 2005 Acura Rsx Type S
                                      • projectk20 has no influence.
                                      Lovin' the new setup. Mint.
                                      "Ted, kiss my shoes"
                                        September 05, 2014, 07:09 PM #45
                                        Josia Offline
                                        Today I was all like "Hurr durr I should post some pictures in my journal". So here we go.
                                        Ken took all these this year because he's a swell guy.
                                          March 30, 2015, 10:47 PM #46
                                          Josia Offline
                                          Haven't updated this in a while.
                                          I have a week off from work so I decided to get some serious work on the car done. Since my father is also not busy this week he graciously offered his assistance. Today we removed the transmission from the car so we could swap out the clutch. The old one was worn down to the rivets already and slipping. Decided not to upgrade and just stick with an Exedy OEM replacement. Tomorrow we'll get the flywheel machined and install the new clutch.
                                          After we get that beast back in the car I'm installing my Invidia 3" catted downpipe, Innovate Wideband, SMY Gauge Cluster, Feal 441 Coilovers and summer wheels and tires. I was gonna have my wheels powdercoated a different color but I couldn't make up my mind so I'll probably just leave them this year and hopefully decide on a color next year. Which is probably when I'll update this again.
                                            March 31, 2015, 07:19 AM #47
                                            BrianMB Offline
                                            • Vehicle: 2005 Subaru Impreza WRX STI
                                            • BrianMB has no influence.
                                            New clutches are nice.... having gone through 2 of them already as well as 2 new flywheels... I can definitely say, I prefer this latest one. Went from stock to Exedy Stage 1 with the heavy duty pressure plate, don't recommend this setup at all. The new setup is the Exedy Stage 2 with the heavy duty pressure plate, and the feedback on the pedal, you can immediately feel when the clutch is engaged. Really nice pedal feel and holds up to the power perfectly.
                                              April 04, 2015, 03:24 PM #48
                                              Josia Offline
                                              This update has some good and bad news. Let's start with the bad news first.
                                              I was doing some datalogging for my new e tune on Thursday. The car was running great and sounded better than ever until I heard this awful noise.
                                              Looks like it's time for a new short block. Stay tuned for more updates.
                                                April 04, 2015, 03:28 PM #49
                                                • Reputation Power: 132
                                                ded
                                                  « Reply #49 on: April 04, 2015, 03:28 PM »
