Author Topic: DYNOJET Dyno Tuning Service  (Read 8623 times)
April 19, 2012, 10:49 AM #0
Speed Factor Offline
  • Speed Factor has no influence.
We are proud to announce that after months of careful planning and discussion with Dynojet, Speed Factor Racing now has a Dynojet 2WD in-ground chassis dyno installed and fully operational. We will be offering full dyno tuning services as well as benchmark services for all 2WD vehicles.
Don’t worry AWD guys! We didn’t forget about you! There are already plans in the works to be able to tune you guys at a later date.
Our Dynojet is installed in-ground to accommodate even the lowest of vehicles and can handle up to 2,000 whp! All of our dyno tuning and testing is performed by Danny Dunning from Overboost Sport Tuning. Danny has tuned some of the quickest vehicles in the city and owns an 800 whp H22A EK Civic hatchback often seen at Gimli during the summer months.
Dynojet Model 224xLC
- Measures up to 2000 + hp and 200mph
- This Model 224xLC can perform load tests including step, sweep and loaded roll-on
- Closed loop load testing is also available by targeting engine RPM, speed or percentage of load
- Dynamometer Chassis (drums, shaft, bearings, etc.)
- Eddy Current Load Absorption Unit, Torque Cell, and dynamic load control software. Perform loaded tests, including step, sweep, and wind drag simulation.
- WinPEP7 Software and Hardware to interface (PC, printer, etc. not included)
- Automatic Conditions Measurement (absolute pressure, air temp, humidity)
- Ignition Wire Inductive Tachometer Pickup Leads
- Air Actuated Brake System
- Remote Software and Brake Control From Driver’s Seat
We will Dyno any 2WD vehicle that can be successfully tied to our Dynojet dyno. Front wheel drive cars, Rear wheel drive cars, Diesel trucks, etc. We have purchased EVERY optional sensor and module offered from Dynojet to make sure your tune is done safely and reliably… as well as make POWER!
DYNO TUNING WAIVER FORMS:
http://www.speedfactorracing.com/?cat=8
Last Edit: April 19, 2012, 11:28 AM by Speed Factor
Speed Factor Racing - Performance Parts & Accessories / Mechanical / Electrical / Dyno Tuning
1875 Pembina Highway, Unit 7 - Winnipeg, MB R3T 2G7
sales@speedfactorracing : http://www.speedfactorracing.com : 204-261-3003
    « on: April 19, 2012, 10:49 AM »
    April 19, 2012, 10:51 AM #1
    Mr.SI2010 Offline
    • Real Name: David Demchuk
    • Vehicle: 2010 Honda Civic SI, 2013 Ford F150 FX4
    • Mr.SI2010 has no influence.
    Cant wait to change my intake and tune!! Then I'll be back
    poppin' vtec like jonny tran
      April 19, 2012, 10:55 AM #2
      For sure!  It was fun seeing your car on the dyno.  We can't hear very well anymore though.
        April 19, 2012, 11:48 AM #3
        Ralliart Guy Offline
        • Real Name: Jack
        • Vehicle: 2009 Mitsubishi Ralliart
        • Reputation Power: 14
        • Ralliart Guy has no influence.
        Damn still no 4 WD Dyno in the province. Sob! Oh well good news for the majority of the group though.  What would be cool is to have a TTI Dyno day maybe get a bunch of people to sign up and possibly get a group rate?
        Too much to list. Check out my build thread
        http://www.clubralliart.com/showthread.php?t=1066
          April 19, 2012, 12:20 PM #4
          We are working on the 4WD section of our Dyno.  It is capable and ready to accept the rear rollers.  We have plans to do a dyno day for TTI later in the summer.  :banana:
            April 19, 2012, 12:37 PM #5
            Is there a set price per pull?
              April 19, 2012, 12:55 PM #6
              Yes, PM sent.
                April 20, 2012, 12:57 PM #7
                Turbo1 Offline
                • Real Name: Jason
                • Vehicle: 13 FRS
                • Turbo1 has no influence.
                Interested in the group dyno day as well :)
                  April 20, 2012, 01:04 PM #8
                  SeñorScooby
                  Let's dyno the Ruckus!
                    April 20, 2012, 04:20 PM #9
                    +1 for ruckus pull lol
                      April 20, 2012, 09:46 PM #10
                      • Reputation Power: 132
                      definitely interested in a TTI group dyno day as well!
                        April 26, 2012, 04:06 PM #11
                        Mr.SI2010 Offline
                        hearing is the week!!
                          April 26, 2012, 06:00 PM #12
                          furmuncher Offline
                          • Real Name: jeff
                          • Vehicle: 93 jdm mr2
                          • furmuncher has no influence.
                          i would like to know cost as well for dyno pulls and i need someone to dial in my cams.i would have the base numbers to set them to but i need someone to tweak them and not charge an arm and a leg to do it :)
                          " look , i can count to crayon "
                          Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
                          Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
                            April 26, 2012, 06:33 PM #13
                            Message sent to you.
                              May 29, 2012, 09:58 AM #14
                              tylerspeed3 Offline
                              • Vehicle: 2008.5 MazdaSpeed 3
                              • tylerspeed3 has no influence.
                              how much is it for a dyno run?
                              Guy on crotch rocket - "Does that car have an STI exhaust?"
                                May 29, 2012, 12:12 PM #15
                                Ill put my truck on it if benz88 does :P
                                  May 29, 2012, 03:01 PM #16
                                  Message sent.
                                    June 20, 2012, 12:44 PM #17
                                    Commanderwiggin Offline
                                    • Vehicle: BMW M3
                                    • Commanderwiggin has no influence.
                                    When is this?  July 14 would be perfect IMO ;)
                                    900rwhp Turbo E46 M3
                                    Supercharged Tacoma
                                      June 20, 2012, 01:02 PM #18
                                      ChezoR33 Offline
                                      • ChezoR33 has no influence.
                                      Dyno day would be sweet. That is if you get the awd portion done by then
                                      (OO\SKYLINE/OO) Dude your beds a car! yeah but its a f@#$ing sweet car!
                                        June 20, 2012, 01:46 PM #19
                                        Josh Offline
                                        • Real Name: Josh
                                        • Vehicle: 2007 Audi A4 2.0T
                                        • Josh has no influence.
                                        I second this.
                                          July 16, 2012, 05:40 PM #20
                                          • Vehicle: BMW M3
                                          Anyone interested or if you booked an appointment for the dyno the location is: 1465 Chevrier Boulevard Unit C
                                          The dyno is at a separate location and isn't listed on their website...I missed my appointment this morning because I wasn't aware of this.
                                          Supercharged Tacoma
                                            August 23, 2012, 07:17 PM #21
                                            gameface Offline
                                            • Vehicle: X W/ JZ
                                            • gameface has no influence.
                                            How much is a run?
                                            Also how much is it to rent the dyno per hour?
                                              August 23, 2012, 07:57 PM #22
                                              Toadal4 Offline
                                              • Real Name: Bryan Boulet
                                              • Vehicle: 2013 Scion FR-S
                                              • Toadal4 has no influence.
                                              would love to get a price :) thanks guys
                                                August 24, 2012, 04:32 PM #23
                                                Message sent to you two.
                                                  August 26, 2012, 12:46 PM #24
                                                  Shier Offline
                                                  • Real Name: Greg
                                                  • Reputation Power: 56
                                                  I'm wondering how much a pull on the dyno would cost as well?
                                                    « Reply #24 on: August 26, 2012, 12:46 PM »
