Author Topic: Plasti Dip  (Read 13368 times)
April 20, 2012, 01:04 PM #0
Turbo1 Offline
  • Real Name: Jason
  • Vehicle: 13 FRS
  • Turbo1 has no influence.
Seems like lots of people are using it now. Anybody tried it on their cars here?? If you are wondering where to go it, I ordered it at $13 a can from piston ring (cheapest i've found without driving to grand forks). Planing on doing my rims in this. Will take some pics when they are done.
Colours they have in canada are black, white, and red i believe.
    Plasti Dip
    « on: April 20, 2012, 01:04 PM »
    April 20, 2012, 01:30 PM #1
    ^ what your paint over the pink!?!?! the pink aint bad it kind of grows on ya. Just make sure you use like a 400 grit sand paper or the stuff prob wont stick to well.
      April 20, 2012, 01:36 PM #2
      Turbo1 Offline
      • Real Name: Jason
      • Vehicle: 13 FRS
      Yah, just changing up the look. I like the pink, but just going for a more "race" look. Its fully reversible as plastidip claims to come off in sheets when you want it to.
      Just gonna clean the rims really good with rubbing alcohol.
        April 20, 2012, 01:37 PM #3
        El Dorifto Offline
        • Real Name: Evan
        • Vehicle: 93 JDM Impreza WRX Turbo, 47 Ford Rat-Rod
        • Reputation Power: 14
        • El Dorifto has no influence.
        Shouldnt be any need to sand. This guy did his whole Audi in it...
        Also to help you out with the rims, a little tutorial. Glad to see someone else using the index card idea to ;)
        - Mechanic/ Autobody extroadinaire (No longer taking in new projects/ work as of Oct/10/2013 till all current ones are finished)
        - http://www.youtube.com/TheLou1
        - 93 JDM Impreza WRX Turbo
        - 47 Ford 3 Window Pick-up Rat-Rod (ground up rebuild)
        - 47 Mercury Sedan Lead Sled (ground up rebuild
          April 20, 2012, 01:41 PM #4
          Turbo1 Offline
          • Real Name: Jason
          • Vehicle: 13 FRS
          ^thanks. I've been watching some vids on it. Seems like the biggest mistake people make is that they put too heavy of coats on at a time. esp the first and second coats.
            April 20, 2012, 01:53 PM #5
            El Dorifto Offline
            • Real Name: Evan
            No problem. Ive done plenty of auto-body work in a shop before. And plus its pretty much common sense that several light coats are better than a couple heavy coats. Sure it takes longer (waiting 15mins or so between each coat for most spray jobs), but the end results are worth it, especially if you've prepped the item properly also.
            Good luck and post up a DIY in the DIY section. I know a few other people are curious of this product.
              April 20, 2012, 04:12 PM #6
              audidrive Offline
              • Vehicle: 2007 Audi A4 2.0T
              • audidrive has no influence.
              hey  i have done lots of trim on my Audi with it and its great easy to work with, looks great and very much revercible ,but for the rims it might not be as durable and last as long ,would love to see how it turn out though .
              got boost ?
                April 20, 2012, 04:33 PM #7
                • Reputation Power: 168
                Would you be able to do this on say, rear emblems?
                And would it be possible to peel away the over spray easily?
                  April 20, 2012, 04:48 PM #8
                  audidrive Offline
                  yes and yes i still got to tape it off a lil bit couse its a pain to clean up the little dot over spray . ill post some pics tonight of it and if u  are at the cruse tonight feel free to chek it out .
                  got boost ?
                    April 20, 2012, 05:54 PM #9
                    Ill be there!
                      April 20, 2012, 06:03 PM #10
                      Faken Offline
                      • Vehicle: 2008 Honda Fit
                      • Reputation Power: 141
                      • Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!
                      how easy does this stuff come off? I might just do this to the rims.
                      http://www.flickr.com/photos/kenau/
                      All photos that are taken by me can be used for whatever you want!
                      "I love Honda's because I started with Honda's" - Ryan Basseri
                      Ken
                      [Mar 26 13:45:26] Igor:hearts before parts
                        April 20, 2012, 11:23 PM #11
                        Looks like it simply peels off.
                        Thats also what Audidrive told me tonight (sorry didn't catch a name)
                          April 20, 2012, 11:48 PM #12
                          JayPe3 Offline
                          • Reputation Power: 67
                          Plasti-dip just peels off. If you plasti-dip the whole car, the seams between body parts (IE Trunk and tail lights) is enough to tear it. Just lift a piece, and slowly pull it off. Plasti-dips honestly a blessing, and is a really good idea for almost anything.
                            April 21, 2012, 12:01 AM #13
                            b00duh Offline
                            • Vehicle: 2006 Saab 9-2x
                            • b00duh has no influence.
                            I was planning on spraying the car with white plastidip in the beginning of May.  lol.  I've done paint before and the worst part to work with is the clear coat.  I have some severe orange peel on the saab that I'm slowly sanding down.  lol.
                            Need stuff picked up from a parcel company @ the border?  PM me for more details!
                              April 21, 2012, 07:55 AM #14
                              audidrive Offline
                              im Andrew by the way ,and it is that simple
                              Originally posted by b00duh
                              I was planning on spraying the car with white plasti dip in the beginning of May.  lol.  I've done paint before and the worst part to work with is the clear coat.  I have some severe orange peel on the saab that I'm slowly sanding down.  lol.
                              there is no need for sanding maybe if there are super rough sports ,and also i dont think there is a clear coat its just appears as a flat colour
                              got boost ?
                                April 21, 2012, 10:45 AM #15
                                Faken Offline
                                I'm just curious how you'd clean the wheels when they get dirty. Won't the pressure washer just complete destroy the plastic dip off the wheels?
                                Ken
                                  April 21, 2012, 11:08 AM #16
                                  audidrive Offline
                                  surprisingly  no  i tried to point  the wand right at it at the car wash last night, and its pretty tough ,pretty amazing product
                                  got boost ?
                                    April 21, 2012, 11:09 AM #17
                                    Riley Online
                                    • Vehicle: '15 Fiesta ST, '00 MX5 S/C
                                    • Reputation Power: 120
                                    Hmmm. I might plasti dip my rims to see how I like em in white before powder coating them
                                      April 21, 2012, 12:17 PM #18
                                      Faken Offline
                                      That's exactly what I'm doing. People say that Homehardware sells this stuff and piston ring? What other stores in Winnipeg sells this stuff?
                                      EDIT: Also, is it 100% neccessary to unmount the wheels to do this? What if i just cover the brakepads and tires while it's mounted on the wheel.
                                      Last Edit: April 21, 2012, 12:18 PM by Faken
                                      Ken
                                        April 21, 2012, 12:30 PM #19
                                        JayPe3 Offline
                                        Canadian Tire in Selkirk sells them. We should trip out to Selkirk as a group and grab some cans!
                                        Just make sure everything you're going to plasti dip is CLEAN. Clean it, degrease it, go to the 9's.
                                          April 21, 2012, 01:02 PM #20
                                          Faken Offline
                                          Of course! So does that mean all CT sell it? $15 a can?
                                          Ken
                                            April 21, 2012, 01:24 PM #21
                                            Riley Online
                                            $20 a can at home hardware I think
                                              April 21, 2012, 01:31 PM #22
                                              Faken Offline
                                              The one on Pembina in Winnipeg?
                                              Ken
                                                April 21, 2012, 01:49 PM #23
                                                Riley Online
                                                That's the advertised price online. I'm gonna order from the states, $36 shipped for 4 cans.
                                                  April 21, 2012, 03:00 PM #24
                                                  • Reputation Power: 29
                                                  • Eppic barely matters.Eppic barely matters.
                                                  i'm driving to orlando next weekend. if i can fit it in my tiny car, i'll bring back a bunch for ya'll
                                                    Plasti Dip
                                                    « Reply #24 on: April 21, 2012, 03:00 PM »
