Author Topic: The L  (Read 11969 times)
August 13, 2013, 07:36 PM #25
Anne Goose Offline
  • Reputation Power: 42
  • Anne Goose might someday be someone...Anne Goose might someday be someone...Anne Goose might someday be someone...Anne Goose might someday be someone...
Is this the one Dan hit?
[Dec 08 16:45:00] Adomp:do I talk to autter about that? I thought she was the person to speak about the UHL
[Dec 08 16:44:39] Adomp:is there a an Ugly Hockey League? event like this wont happen again.
    The L
    « Reply #25 on: August 13, 2013, 07:36 PM »
    August 13, 2013, 07:38 PM #26
    slipstreamconversion Offline
    • Real Name: Darcy
    • Vehicle: 1997 Toyota Aristo / 1993 Toyota Camry
    • slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.
    No.  That's my other car.  Let's stay focused here :P
      August 13, 2013, 07:51 PM #27
      I want story.
        August 13, 2013, 08:11 PM #28
        • Real Name: Darcy
        My questioning here, is if I emery cloth the piston faces, (which would take out most of the marks) and put new valves and head gaskets in, if this thing would be good to go for the winter, then in the spring actually worry about swapping engines?
        That is, if it's a cheaper option.
          August 13, 2013, 08:12 PM #29
          • Real Name: Darcy
          Originally posted by: S.Bretz - sixthsphere.com
          The motor is ****... get a used one and install a new water pump, timing belt, thermostat and reseal the oil cooler.
          It cost more to rebuild the heads and replace the pistons than it does to get a new motor.
          Again, when the valves get bent on those heads, you need to replace the valve guides too. That's where things get expensive.
          Ah.  Damnit.
            August 13, 2013, 08:32 PM #30
            Darkstar Offline
            • Real Name: Aaron
            • Vehicle: 2012 Scion tC
            • Darkstar has no influence.
            Do you by chance have any links to an ecotech swap? I wouldn't mind takin a look.
            No matter what you choose to do we will get this beast running.
            2012 SCM Scion tC
            1997 Super Red Toyota Paseo - Gone but never forgotten!!
              August 13, 2013, 11:40 PM #31
              Yup if the valves bent your guides are NFG. Technically the block is still good, but cost wise you might as well swap engines.
              Or if you can find a set of heads to bolt on, but new gaskets/seals/timing stuff is gonna add up.
              Good on ya for taking it apart yourself. It was as I originally feared.
                August 14, 2013, 12:46 AM #32
                • Real Name: Darcy
                Would the heads of a different engine have to be machined to match the block?
                Looks like a new engine is in the near future..
                  August 14, 2013, 12:57 AM #33
                  Yes. And the block is aluminum, so it needs machining too. Forget I said that. Sounds like you need a motor.
                    August 14, 2013, 01:07 AM #34
                    You should let Dan drive it
                      August 27, 2013, 03:15 PM #35
                      • Real Name: Darcy
                      Heads going back on so the engine mount can bolt in it's original three places, will be winter stored until spring when it gets a new engine.
                      However..  sixthsphere has finally posted pictures of the modified Vectra B coilovers they will have available.  Awh yeah.  I'm gonna get my paws on these in the spring.
                        August 28, 2013, 05:57 PM #36
                        August 28, 2013, 08:31 PM #37
                        Ænimal Offline
                        • Vehicle: Miater, so many bikes
                        • Reputation Power: 75
                        • Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.Ænimal has a powerful will.
                        Wait, why on earth would you buy coil-overs for that?
                        [Aug 01 15:48:26] dolan:Guys i really dont care, im still young enough to learn from all my mistakes.
                          August 28, 2013, 08:58 PM #38
                          Because lower is better..  Comon Nish, you should know this by now! :P
                            August 28, 2013, 09:12 PM #39
                            Stefan Offline
                            • Real Name: Stefan
                            • Vehicle: 2004 WRX wagon
                            • Reputation Power: 48
                            • Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...
                            #becauseracecar
                            build it - race it -  break it - do it all over
                              August 28, 2013, 09:21 PM #40
                              dolan Offline
                              • Real Name: Dyllan
                              • Vehicle: 2000 civic si
                              • Reputation Power: 0
                              • dolan is looked down upon.
                              Originally posted by Stefan
                              #becauseracewagon
                              Fixed that for ya ;)
                              Sent from my SGH-I747M using Tapatalk 2
                              Dyllan Angelkovski (aka) Dyllan Africa
                              [Mar 27 22:16:27] Uncle Hugh Myron:i bet PEAVEY MART NOW OPEN has it
                                August 29, 2013, 09:52 AM #41
                                sm1ke Offline
                                • Real Name: Mike
                                • Vehicle: 2008 GSE25
                                • sm1ke has no influence.
                                Damn you got this thing for an awesome price, even factoring in the cost of a new engine. I'd love to have this for a winter beater/road trip beater. I personally wouldn't spend money on it trying to make it look nice, but its not my money or my car :P
                                Last Edit: August 29, 2013, 09:54 AM by sm1ke
                                  August 29, 2013, 09:55 AM #42
                                  • Real Name: Darcy
                                  Thanks Mike!
                                  We shall see how she goes :)
                                    August 29, 2013, 10:08 AM #43
                                    evo1 Offline
                                    • Real Name: Mitch
                                    • Vehicle: 1992 Lancer Evolution RS, 6.7 SRW Mega Cab 3500
                                    • evo1 has no influence.
                                    Ecotec swap would be great. Please go through with that portion of it.
                                      August 29, 2013, 10:38 AM #44
                                      • Real Name: Darcy
                                      Yeah, I've got a ton of information and a parts list started.  Having the discount at Bucks auto parts helps immensely lol.
                                      As I've never done swaps and stuff, most likely gonna reach out for help in the spring.
                                        August 29, 2013, 10:51 AM #45
                                        Buy MPI write off with rear end damage.  Swap everything needed.
                                        Unless everything at bucks is free lol.
                                          August 29, 2013, 11:17 AM #46
                                          evo1 Offline
                                          • Real Name: Mitch
                                          I don't think that these get written off very often....
                                          Darcy, let me know if you need anything from wesman salvage. January/February I will be traveling from Brandon to wpg weekly. :)
                                            August 29, 2013, 11:29 AM #47
                                            • Real Name: Darcy
                                            Yeah, most of the stuff from Bucks I get for relatively nothing.
                                            Sounds good Mitch!  I'll keep you posted, I gotta start a thread on Sixthsphere about a possible parts list.  I'm assuming stuff like the ECM, other various connections, but I will have to see if that transmission mates with an ecotec, or if the transmission has to go too.
                                              August 29, 2013, 11:40 AM #48
                                              It doesn't. You will need the Ecotec trans and literally everything else. You might as well find a whole wrecked car of a similar year, cause you will need the engine mounts, the exhaust (unless you build custom) the shifting mechanism, clutch stuff, ECU, sensors etc etc.
                                                August 29, 2013, 11:50 AM #49
                                                • Real Name: Darcy
                                                Hmm.
                                                I got time to weigh my options, the V6 swap is easier, just harder to find, and I gotta stay on top of the timing belt replacing.
                                                But ecotec seems a tad more reliable.  As I said, I got time, just going to do my research and move forward from there.
                                                  The L
                                                  « Reply #49 on: August 29, 2013, 11:50 AM »
