Author Topic: DIY: Brake Pads and Rotors  (Read 3211 times)
May 08, 2012, 10:46 AM #0
TonyPajamaz Offline
  • Vehicle: 2012 Audi A4, 1996 Mazda MX-5 Miata
  • Reputation Power: 78
  • TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.TonyPajamaz has a powerful will.
Hey guys, this past weekend I got my new brakes in so I figured it would be good to take a couple pictures and write up a DIY on toptier.
I didn't really know what type of brakes I had on my car when I got it, but they where very squeaky and were creating lots of dust. They still had lots of life left, but the noise and dust were driving me nuts.
I decided to go with OEM rotors (because the ones on the car looked like fake slotted ones), and HAWK HPS brake pads. For the Evo IV the rotors matched up with an 06 Outlander, and the front pads match up with a 93+ Talon TSI, So I was able to get all of my parts from Speed Factor Racing.
Here is my work station:
For this type of job just a regular ratchet set will do. I find it's good to have a hammer to help brake bolts and some brake cleaner to spray down the calipers after taking off the pads and for the rotors after they are on the car. Other things include the obvious, Jack, Jack stands, tire iron etc.
This is what the old set up looked like. No clue what the rotors were, but after taking the pads off it appears they are Project Mu pads which explains why they were so loud and gave off so much dust. They were also very grippy, which makes sense now too.
These are the 2 bolts on the back of the caliper, the interior one is the one that fastens it to the hub, the outer one needed to be loosened to allow the caliper to move when putting the new pads on. There are 2 sets of bolts 1 on the top as you see and another on the bottom in the same spots. The 2 bolts holding the caliper to the hub will need to be removed to take the caliper off so that the rotor can be removed.
Once the caliper is off, the pads literally just needed to be poked out of place.
To get the pistons back down, I kept the old pad in place, put the caliper back on and used the extension in the picture as a wedge and it slowly pushes the piston back down. This needs to be done as your old pads will be slimmer then then new pads and if you don't, you won't be able to fit the new brake pads on to the rotor as there won't be enough clearance.
This is the new OEM rotor compared to the old one.
Old pads on the bottom, HPS pads on top, notice how they already come with backing plates already on!
To put the new pads on, you just do the opposite of everything you did to take it off. Put your pads into their slots, put the new rotor on to the hub, slide the caliper back on to the rotor and bolt the caliper in place. and Voila, you are done your brakes.
This took me about 3 hours as I had never dealt with this type of caliper before and took a little bit of trial and error to figure out what I needed to do. It should have only taken about 1.5 hours, but it all depends on how fast you work.
As always, make sure your bolts are tightened back up to spec, and that all bolts are put back in place. Always pump your brakes several times untill you feel stiffness coming back into them, never drive off right after replacing brake components. Torque your lug nuts back up properly and enjoy your new brakes.
This is how dirty I got from doing the front brakes lol
I'll write a review on the pads in the review section to follow up on the install.
Last Edit: December 11, 2014, 11:01 AM by Ænimal
[Jan 01 21:16:06] Faken:most steady hand/10
[Sep 23 14:27:56] Faken:i was focusing on dan's bum
    « on: May 08, 2012, 10:46 AM »
    May 08, 2012, 10:55 AM #1
    Nice one Tony. Next time don't rub your face on everything.
      May 08, 2012, 11:03 AM #2
      TonyPajamaz Offline
      lol I tried to sneak my head back there to see the bolts and then boom, big streak on my face haha.
        May 08, 2012, 12:04 PM #3
        Great write up! Ive never understood why dealerships charge $200+ for brake replacements. It takes like 30 minutes max.
          May 08, 2012, 12:06 PM #4
          Hahaha, good write up man.
            May 08, 2012, 12:26 PM #5
            Good stuff.
            Never had to do pads myself yet, but im sure this will come in handy sooner or later.
              May 08, 2012, 02:39 PM #6
              Rush Offline
              • Real Name: Wlad
              • Vehicle: 2004 AUDI S4
              • Reputation Power: 18
              • Rush has no influence.
              GITRRR DONE. Nice write up Tony. Why oem rotors?
              '04 Audi B6 S4   -   '94 BMW E34 530i Touring
                May 08, 2012, 06:52 PM #7
                JayPe3 Offline
                • Reputation Power: 67
                We have a badass over here.
                Good job buddy, nice write up.
                  May 08, 2012, 10:53 PM #8
                  TonyPajamaz Offline
                  I've never been a fan of upgraded brakes on a street car, So I figured I would go with at least an autocross pad that had bite, didn't give off dust, was quiet, and let it do all the work.
                  Oem rotors were less then 40 bucks a side. I would never buy drilled rotors as I hear they can warp especially as most drilled rotors are drilled after they are made, which is just as bad as drilling oem rotors. Slotted do help release any gas created between the pad and rotor, but they cut down your pad life.
                  Thanks for the compliments guys, if anyone needs help doing heir brakes just let me know.
                    May 10, 2012, 12:09 PM #9
                    Rush Offline
                    • Real Name: Wlad
                    What I heard about drilled rotors was they can crack in between the holes, never seen a case tho. Also which kind of drilled rotors are not drilled after they are made?
                    Last Edit: May 10, 2012, 12:13 PM by Rush
                      May 10, 2012, 04:37 PM #10
                      TonyPajamaz Offline
                      The good kind lol. Anything very high end. The rotors that come drilled stock on a Ferrari for instance, would be molded with holes in it.
                        May 11, 2012, 10:18 PM #11
                        El Dorifto Offline
                        • Real Name: Evan
                        • Vehicle: 93 JDM Impreza WRX Turbo, 47 Ford Rat-Rod
                        • Reputation Power: 14
                        • El Dorifto has no influence.
                        Great right up Tony. And you wont be dissapointed with those Hawk pads thats for sure. Loved mine in my cars.
                        - Mechanic/ Autobody extroadinaire (No longer taking in new projects/ work as of Oct/10/2013 till all current ones are finished)
                        - http://www.youtube.com/TheLou1
                        - 93 JDM Impreza WRX Turbo
                        - 47 Ford 3 Window Pick-up Rat-Rod (ground up rebuild)
                        - 47 Mercury Sedan Lead Sled (ground up rebuild
                          May 12, 2012, 01:58 PM #12
                          May 13, 2012, 09:52 PM #13
                          great write up... hope to do one this weekend when I replace my calipers...
                            May 13, 2012, 11:04 PM #14
                            • Reputation Power: 132
                            I did my brakes once. Had no idea what I was doing really but it worked out. Now I'm thinking I need to do my rear ones on my Z.
                              May 14, 2012, 01:30 AM #15
                              TonyPajamaz Offline
                              Please do! I think I may have a bubble in my brake line, and I'd like to see how to bleed the brakes or burp the system.
                                May 23, 2012, 10:54 PM #16
                                Stoyka Offline
                                • Real Name: Brendin
                                • Stoyka has no influence.
                                Nice write up, I was just trying to convince a friend to do theirs today but they suck so they are gonna waste money at a shop.
                                Id also like to add, when I do my brakes I like to put a little bit of red silicone between the piston and the pad just to give it that bit of extra grab so it doesnt get stuck against the rotor. I dunno if that actually makes a difference, I like to think it does. Also, princess auto sells a tool thats basically a bolt with a handle on one side that goes through a plate. The plate goes against the caliper bracket, screw the handle and it pushes the piston back in.
                                http://www.princessauto.com/pal/product/2990006/Brakes/Disc-Brake-Spreader
                                Really easy to use and it saves you jamming an extension in there!
                                  May 24, 2012, 12:35 AM #17
                                  TonyPajamaz Offline
                                  I should have added it in the write up, but as you can see in the last picture, I did spread the recommended 1-2 grams of red lubricant on the back of the pad to prevent squealing.
                                  That's a good tip for depressing the pistons, you can also just use a regular clamp with something wide enough to cover the face of the piston.
                                    May 24, 2012, 07:41 AM #18
                                    I WAS A MAN AND USED MY HAND... for my rear calipers I had to use a c-clamp for the fronts way to hard lol
                                      May 24, 2012, 10:44 AM #19
                                      Easiest way is if you have a slot or opening in the top of the caliper, you can pry the caliper against the rotor while its still on the car, and the pistons will compress back in.
                                        May 24, 2012, 06:55 PM #20
                                        TonyPajamaz Offline
                                        Yeah my back ones went in like butter haha!
                                          September 13, 2012, 10:34 PM #21
                                          this is a good DIY
                                            September 14, 2012, 12:06 AM #22
                                            TonyPajamaz Offline
                                            Originally posted by sunshine
                                            this is a good DIY
                                            Thanks man, have you replaced the brakes in your car yet?
                                              September 14, 2012, 01:15 AM #23
                                              Did my fronts for the second time this year :(
                                                September 14, 2012, 08:21 AM #24
                                                Me too. After 2-3 months they start to squeak again under super light pressure. Not sure what is going on.
                                                  How To: Brake Pads and Rotors
                                                  « Reply #24 on: September 14, 2012, 08:21 AM »
