Author Topic: 2013 Subaru BRZ Build Thread  (Read 109776 times)
December 08, 2013, 10:55 AM #0
Alex2NF Offline
  • Real Name: Alex
  • Vehicle: 2013 Subaru BRZ - 2004 Toyota 4Runner
  • Reputation Power: 234
  • Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!Alex2NF is awe-inspiring!
Alex's 2013 Subaru BRZ Build
Initial post was moved below. I'm going to use this one for a current pic and the mod list.
How it looked when I picked it up in October of 2013
How it looks as of 07/09/2016
How it looks as of 05/15/2016
How it looked as of 10/31/2015
Alex's BRZ by Shaun Jeroski, on Flickr
Current Mod List: *Updated 03/05/2016
Suspension, Brakes, and Wheels
17x9" +35 GramLights 57DR Gun Blue
Project Kics R40 Black Lugs
245/40/17 Continental Extreme Contact DW
245/40/17 BFG Rivals
265/35/18 Michelin Pilot Super Sports
Enkei RS05rr 18x9.5 + 43
HKS Hipermax Max IV GT Coilovers
Work CR2P 18x9.5 +15 (Front)
Work CR2P 18x11 -15 (rear)
Falken Azenis FK453 255/35/18
Falken Azenis FK453 295/30/18
Buddy Club front control arms with racing ball joints
Buddy Club rear lower control arms
Hotchkis Front and Rear Sway Bars
Perrin control arm braces
Whiteline rear sway bar braces
Whiteline rear end links
Whiteline camber bolts
Whiteline rear subframe bushings
StopTech front/rear stainless steel brake lines
Motul 600 brake fluid
Motul 300v 0w20 oil
Motul Gear 300 75w90 for Transmission and Differential
STI Brembo Front and Rear brake calipers
Hawk HPS Front Brake Pads
Hawk HPS Rear Brake Pads
DBA T3 4000 Slotted Front Rotors
DBA T3 4000 Slotted Rear Rotors
KNS Brake rear caliper brackets
Speedbleeders
AVO Anti-Tramp rear differential bushing inserts
Kics Iconix black lugnuts <--- do not buy
Ichiba hubcentric spacers 10mm with extended studs (front)
5mm hubcentric spacer (rear)
H&R Trak 30mm Spacer (Front)
Blox 60mm Spacer (rear)
Air Lift performance Front struts
Air Lift performance Rear struts
Airt Lift Autopilot V2 air managment
Accuair 5gal air tank (powdercoated gunmetal grey)
Custom DOT approved PTC 1/4" air fittings (bulkhead)
Air Lift Performance 3h Management
Work RSR Lug Nuts in black
Engine and Drivetrain
Perrin Light Weight Water pump and Alternator Pulleys
Perrin Master Cylinder Brace
Whiteline Transmission bushings
MTEC Shifter Springs
Kartboy Short shifter + Bushings
ECUTEK Cable + License
AVO Stage 1 Turbo Kit
AVO 50/50 Blowoff Valve
AVO Crossover Pipe (Ceramic Coated)
GrimmSpeed hood struts
GrimmSpeed exhaust gaskets
AEM Boost/AFR Failsafe Gauge
Innovate MTX-L Oil Pressure/Temp Gauge
Block8Head Custom defrost vent gauge mount
ATI Vent Pod gauge mount
Blitz EU GT86 specific Oil Sandwich plate with spacer
Grimmspeed black engine cover
Vibrant T-Bolt Clamps
Vibrant Vacuum Manifold
Vibrant Hose Clamps
Spencer Fabrication custom vent hard lines
Treadstone turbo blanket
ProSport remote oil pressure line
Custom dual catch can setup made by Saikou Michi
Perrin 3" Catback Exhaust
AVO 3" Downpipe
AVO 3" Ceramic Coated Overpipe
AVO 3" Ceramic Coated Front Pipe (no cat)
Perrin Cold Air Intake in Black
Delicious Tuning ECBS
Delicious Tuning Speed Density Tune (4 maps)
Target Based Boost Control
Full Blown Motorsports Oil Cooler
Exedy Stage 1 Clutch and Flywheel
Full Blown Fuel Pump setup with Warlboro 485
DW 450cc Port Injectors
Omni 3 Bar Map sensor
Gates Racing V-Belt
Full Blown Motorsports Aluminum Radiator
Full Blown Motorsports Aluminum rad shroud
Dual SPAL rad fans
Chase Bays coolant overflow tank
AVO upgraded 8 PSI actuator
P-Tuning Water/Meth Injection Kit with lightweight battery mount
Odyssey PC680 Battery
Optima Yellow Top battery
Fragola Oil Cooler Lines
Greddy Type FV Blow off valve
Spencer Fabrication throttle body spacer and WMI injection plate
Cusco Liquid-to-Liquid oil cooler
STI Engine Mounts
Cusco Air/Oil separator
IAG billet aluminum master cylinder Cap
IAG billet aluminum clutch reservoir cap
IAG billet aluminum complete dipstick replacement
IAG billet aluminum washer fluid reservoir cap
Prova aluminum oil cap
Apexi coolant cap
Raceseng aluminum oil filter cover
APR Carbon Fiber cooling plate
GReddy Profec II Electronic Boost Controller
GReddy Type FV Blow Off valve
Interior, Audio, and Aero
GReddy Rocket Bunny V2 side skirts
GReddy Rocket Bunny V2 rear over fenders
GReddy Rocket Bunny V2 front bumper
GReddy Rocket Bunny V2 DRL Switchbacks
LED Conversion for all bulbs in the car (plate, interior, trunk)
GReddy Rocket Bunny V2 rear diffuser
DAI Yoshihara canards
Tiburnt m6 burnt titanium fender bolts
Amber LED front signal indicators
35% Tint
Toms JDM red tail lights
Hella Supertones
Perrin aluminum shorty antenna
Grimmspeed front license plate bracket
STi JDM rear wing gurney flap
STi JDM Push Button Start
Alpine PDXF4 component amplifier
Alpine PDXM6 subwoofer amplifier
JL C3 650 Speakers (front)
JL C2 350 Speakers (dash)
JL C3 650 Speakers (rear)
JL 10" WS3 Subwoofer
Hertz 10" HX2505 Subwoofer
JL sealed subwoofer enclosure
Custom subwoofer box with compressor mounts
Dynamat Extreme
Weathertech All Season Mats
Backup Camera
Debadged rear
Cusco aluminum E-Brake knob
Eur Toyota OEM arm rest
Aus Toyota OEM Black interior conversion
Rexspeed convex and polarized rear mirrors
Subaru Autodimming Homelink Mirror
Cipher Harness Bar
Takata Drift III Harnesses in Black (driver and passenger)
CaFi Dashlinq4 Toyota Universal headunit
DAMD Carbon Fiber core steering wheel
Prova shift knob
Custom hand made carbon fibre 3rd brake light relocation
Password:JDM Carbon Fibre 3 Piece front splitter
Password:JDM Carbon Fibre Side Skirts
Aero Jacket 1 piece carbon fibre trunk lid with duckbill spoiler
Driver and passenger Bride RO BRZ specific rails
Edirb 023 red stitch seats (driver and passenger)
Seibon carbon fibre hood type DV
Diode dynamics 6k HID headlight bulbs
Move Over Racing front bumper quick release kit
Longacre black adonized splitter support rods
Valenti smoked side markers
JDM Subaru Fog light housings (DRL Deletes)
Prova fender vents
OLM Vision+ DRL LED fog light housings and LED foglights
KMO Activities Todoroki front 30mm fenders
Workshop12 brainiac complete center console replacement with 10" touch screen
Workshop12 Air ride integration
APR Carbon fiber front splitter with support rods
Custom carbon fiber side skirt extensions Race Creations is a scammer. Do not use.
Immediate Future plans:
Front and rear strut tower braces (undecided on brand) <--- FINALLY! A STRUT BAR!
Last Edit: July 11, 2016, 10:10 AM by Alex2NF
13 Boosted Subaru BRZ
04 Toyota 4Runner V6 Sport
∞ Toyota Echo Race Car
98 Acura Integra Race Car 2
IG: @alexdbrz / Twitter: @ToyotaWinnipeg / Snap: OilMyPencil
    « on: December 08, 2013, 10:55 AM »
    December 08, 2013, 11:10 AM #1
    Alex2NF Offline
    • Real Name: Alex
    So I figured I would start an actual build thread on here. I had one on a different site, but it seems like the discussions on that site tend to be anything but automotive focused. I've been creeping over the past week and this site is actually a breath of fresh air. It seems to be actually automotive themed and populated by enthusiasts. Anyways, on to the important bits:
    2013 Subaru BRZ Sport Tech Package 6-Speed
    It's strictly a summer vehicle that will hopefully never see snow. Plans thus far started as "just a few little things" but has blossomed into a long wish list. My intentions are to keep the car indefinitely, so I'm in no rush. Just given the nature of the vehicle, if I upgrade a part I want one of the benefits to be reduced weight. The one exception being some type of sound deadener because I'm a bit of an audio snob, and forced induction.
    I've been following the FT86 concept since it was announced a few years ago. I was actually extremely bitter that Toyota decided to market it as a Scion in North America. The Subaru/Toyota/Scion are pretty much mechanically identical. I had to go to Subaru Calgary to get the car this past October because Frontier Subaru only had a manual in Silver. I ended up with the Subaru over the Scion due to options and equipment. I've become accustomed to certain creature comforts and the Scion didn't come with Leather/Alcantara seats. Also, with the Scion, in order to get push button start, auto climate, and HID's, you had to get the "10" edition which was a limited numbered edition that only came in Silver, and had gross illuminated logos.
    The day I picked up it, Oct 15 2013:
    I work for a Toyota dealer in town, so before I went to Calgary, I ordered a TRD Catback exhaust and it was waiting for me when I got home. It's probably one of the easiest installs I've ever done. My brother had the mid-pipe and muffler off before I had my new garage creeper together. I'm not sure how I feel about the TRD exhaust overall. It's the only aftermarket muffler with that shape of tips and I'm not sure if I prefer circle ones. The upside is that the exhaust is one of the quietest of the aftermarket offerings with a nice smooth and deep tone. I'll be installing a header with a cat delete next week, so we'll see how it sounds then.
    I told myself I was going to pace myself with mods, but that was a complete lie. Within days, I had my mind up that I needed to take care of some of the bigger items on the list. The wheels/tires were the first to go. Here's a shot of the stockers with the Prius compound tires
    The temptation to go with a mad-tyte staggered flushhhhhh setup was pretty great, but I ended up going with a 17x9 square setup at all 4 corners to try and maintain some balance. After some debate and opinion consideration, I ended up with some GramLight 57DR 17x9 +35mm in Gun Blue. They're slightly lighter than stock, but are also a custom offset that will clear big brake kits without issue. (Future planning!). For rubber, on the advice of some other forum members, I went with Continental Extreme Contact DW's in 245/40/17. Second shot is showing the OEM stack of tires vs the new stack of tires.
    With the tire order, I also pulled the trigger on what the manufacturer calls a "Stage 1 Suspension upgrade". It's basically lowering springs and front/rear sway bars. The drop is mild at 1", but maintains near stock ride quality. I left the struts OEM for now. I may upgrade them, or might go coil overs down the road. The front and rear sway bars are adjustable, so it will keep my options open. I put about 1000km on the car before storing it, and i'm pleased with the ride quality. Very near OEM, but sharper with less body roll.
    The offset and sizing is perfect imo. Wheels are pushed right to the corners without too much poke
    Some Perrin parts arrived shortly there after. A brake master cylinder brace and a pulley
    I was actually shocked how much room is infront of the engine once you have the stock airbox out. Tons of room to do stuff, or install some forced induction plumbing! The pulley literally took 10 minutes to install, and the master cylinder brace was equally trivial
    The next day, my new intake arrived. It's an AFE Takeda dry filter. I also took the time to delete the annoying sound tube. The factory intake has a pipe coming off the main intake that channels sound into the cabin. I capped off the firewall hole, and it sounds so much better without it. It was kind of cool at first, but in the short time I drove the car, I found it annoying.
    STi parts in North America are garbage for this car. We literally get a fraction of what's available over seas. I liked the look of the rear spoiler addon from STi Japan, so I ordered it. It's very subtle, but it "finishes" the spoiler in my opinion. It's the flat black rubber looking thing on the end. Here it is installed:
    Here's a rear shot of the spoiler add-on and my new vanity plate that just arrived
    And that's how the car sits right now. Current parts on order are some Toms JDM tail lights in red, a Borla unequal length header, and some other random small stuff. After that, plans are a full audio system upgrade, sound deadening for the doors and wheel wells, and then who knows. Long term plans are a front and rear big brake kit and an Innovate/Cusco supercharger. I'll update this thread as it progresses. Feel free to share your opinions or if you think something looks stupid :)
    Last Edit: April 03, 2015, 11:37 AM by alexatwork21
      December 08, 2013, 11:18 AM #2
      Saturdays and sundays!
      Awesome start.
        December 08, 2013, 11:42 AM #3
        • Reputation Power: 132
        I agree with bringing this to autocross. Nice start to your build.
          December 08, 2013, 12:51 PM #4
          Nhil Offline
          • Real Name: Josh
          • Vehicle: 2000 Honda S2000
          • Reputation Power: 91
          • Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!Nhil has great potential!
          Nice progress! What did you use to cap the sound tube hole on the firewall? I notice quite a few people do this and I'm interested in that sound difference it makes.
          [Mar 02 10:56:01] TwoFourDee:..ever
          [Mar 02 10:55:59] TwoFourDee:nobody quote me on that
          [Mar 02 10:55:56] TwoFourDee:I actually like those rotas
            December 08, 2013, 12:59 PM #5
            Faken Offline
            • Vehicle: 2008 Honda Fit
            • Reputation Power: 141
            • Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!Faken is awe-inspiring!
            nice! function over form :).
            http://www.flickr.com/photos/kenau/
            All photos that are taken by me can be used for whatever you want!
            "I love Honda's because I started with Honda's" - Ryan Basseri
            Ken
            [Mar 26 13:45:26] Igor:hearts before parts
              December 08, 2013, 01:17 PM #6
              Alex2NF Offline
              • Real Name: Alex
              Canadian tire has some hose end caps in their auto emergency section. One of them fits the grey elbow in the firewall grommet perfectly.
              You can get sound tube delete kits that come with caps for the air box side and firewall side., and trd Japan makes a sound tube upgrade kit with the option to block it off completely. If you're really lazy, a 12v cigarette lighter cap also fits perfectly on the inside of the firewall
              1uz front sump
              R154 JX110 (with removed rear engine webbing)
              motec m150 firmware to run v8
              Last Edit: April 01, 2016, 04:01 PM by Alex2NF
                December 08, 2013, 01:28 PM #7
                SpeedPls Offline
                • Real Name: Greg
                • Vehicle: BCNR33 V-Spec
                • Reputation Power: 69
                • SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!SpeedPls is a rising star!
                I like where this build is headed! I look forward to your future plans!
                My Flickr
                1995 Skyline GTR V-Spec
                1991 Skyline GTR - sold
                1995 Skyline GTR - sold
                  December 08, 2013, 02:30 PM #8
                  Very slick!  Keep it up!
                    December 08, 2013, 06:30 PM #9
                    N1ck Offline
                    • Real Name: Nick
                    • N1ck has no influence.
                    This car is awesome, your previous vehicles turned out great so I didn't expect anything less.
                    1993 Del Sol Si
                    2015 Kia Sportage EX Luxury AWD
                    2015 Chrysler 300 Limited
                      December 11, 2013, 09:55 PM #10
                      Alex2NF Offline
                      • Real Name: Alex
                      A couple items arrived today! Header, tails, and I picked up some hella horns while I was at speedfactor
                      Stock:
                      Installed:
                      The tail lights look much better than stock imo. They are the jdm version and not the US retrofit that has side markers installed by a 3rd party. They are LED, but they came with a new indicator relay to prevent rapid flashing.
                      The header was easy to install. It took about 30 minutes start to finish once the car was in the air. Here's a shot of the factory header and cat compared to the borla header. The weight savings are huge
                      The sound is unreal, imo. It's still nice and subtle but has an awesome rumble to it now. Even though I lost the main cat, the TRD exhaust keeps it smooth and rasp-free, if that's even a word.
                      Last Edit: December 11, 2013, 11:41 PM by alexatwork21
                        December 11, 2013, 09:57 PM #11
                        Alex2NF Offline
                        • Real Name: Alex
                        Vid of how it sounds:
                        *garage was ventilated
                          December 11, 2013, 10:01 PM #12
                          That is a great note. Love it.
                            December 11, 2013, 10:09 PM #13
                            Sounds amazing, and those tails look great! :croatia:
                              December 11, 2013, 10:12 PM #14
                              toms look sweet.
                                December 11, 2013, 10:16 PM #15
                                Faken Offline
                                i approve those taillights. WAY better. Nice rumble :D.
                                Ken
                                  December 11, 2013, 10:20 PM #16
                                  Lou Offline
                                  • Real Name: Louis
                                  • Vehicle: 2017 Toyota 86
                                  • Reputation Power: 35
                                  • Lou is working their way up.Lou is working their way up.Lou is working their way up.
                                  Wow that sounds incredible!!! Dem tails look really nice IMO.
                                    December 12, 2013, 08:52 AM #17
                                    That sounds unreal and those taillights are 100x better than stock.
                                    Are you winter driving this?
                                      December 12, 2013, 09:14 AM #18
                                      Alex2NF Offline
                                      • Real Name: Alex
                                      Nah, parked until spring
                                        December 12, 2013, 10:03 AM #19
                                        Josia Offline
                                        • Real Name: Josia Toews
                                        • Vehicle: 08 GTI, 99 Civic Type R
                                        • Reputation Power: 34
                                        • Josia is working their way up.Josia is working their way up.Josia is working their way up.
                                        I love everything about this.
                                        [Feb 22 17:00:55] Shaun:i hate chatbox
                                          December 12, 2013, 10:04 AM #20
                                          Nhil Offline
                                          • Real Name: Josh
                                          Man those tails look good, header sounds good too. Decided on which tune you're going with?
                                            December 12, 2013, 10:34 AM #21
                                            reyza Offline
                                            • Real Name: Rey
                                            • Vehicle: Honda HRV + Suzuki SV1000S
                                            • reyza barely matters.reyza barely matters.
                                            really nice call on the spoiler and tails. looks sick
                                            Honda HRV
                                            Suzuki SV1000S
                                              December 12, 2013, 10:39 AM #22
                                              Alex2NF Offline
                                              • Real Name: Alex
                                              Thanks for the compliments guys. The tails look good in pictures, but they honestly don't do them justice.
                                              Nhil: I'm still on the fence between OpenFlash and ECUTEK. ECUTEK is way more cash and locked down, but it would be an easy map upgrade if I ever moved to forced induction. The maps with ECUTEK are top notch though, depending on who you buy from. OpenFlash is much less $, but there's just something about open source maps that makes me a little nervous.
                                                December 12, 2013, 05:02 PM #23
                                                BADWAGN Offline
                                                • Real Name: David Sr. [A.K.A. Big D]
                                                • Vehicle: AUDI B7 Avant Stage II+
                                                • Reputation Power: 46
                                                • BADWAGN might someday be someone...BADWAGN might someday be someone...BADWAGN might someday be someone...BADWAGN might someday be someone...
                                                subbed.
                                                'I Hold The Worlds Record for Holding Worlds Records'
                                                'It looks like you were talking when you should have been listening'
                                                'I stuffed it in the lady hole one too many times today'
                                                  December 12, 2013, 07:07 PM #24
                                                  Stefan Offline
                                                  • Real Name: Stefan
                                                  • Vehicle: 2004 WRX wagon
                                                  • Reputation Power: 48
                                                  • Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...Stefan might someday be someone...
                                                  Sounds great! This car is coming together really well.
                                                  build it - race it -  break it - do it all over
                                                    « Reply #24 on: December 12, 2013, 07:07 PM »
