Author Topic: Street Machine --> A tale of an 06 Sti, Cool Video Inside***  (Read 19054 times)
June 24, 2014, 07:46 PM #50
I--RIDE--BIKES Offline
  • Vehicle: SGM 06 STI
  • Reputation Power: 25
  • I--RIDE--BIKES barely matters.I--RIDE--BIKES barely matters.
Thx Josh. So far everything has worked great. I sent the injectors to ID to get cleaned and inspected just to be safe. I also just finished building all of the fuel lines as well. Its so much nicer to be able to build the lines the way you want them compared to a bought kit.
Anyways:
Here are a couple more ghetto phone pics of the DP i just finished welding up today. I still need to add the brace that goes to the tranny and waste gate recirc pipe. I also pick up the intercooler on thursday and should have the piping run by the end of the week.
Insta: @lelandSTI
Ion Coating: Custom powder coating
    « Reply #50 on: June 24, 2014, 07:46 PM »
    June 25, 2014, 12:07 PM #51
    Josh Offline
    • Real Name: Josh
    • Vehicle: 2007 Audi A4 2.0T
    • Josh has no influence.
    Yeah, not a bad idea getting them checked out. How much did that set you back?
    Anyway, things look good.  Sorry for thread jacking.
      June 25, 2014, 12:26 PM #52
      haha no problem. Its about $25 per injector i believe
      Insta: @lelandSTI
        June 25, 2014, 02:24 PM #53
        Josh Offline
        • Real Name: Josh
        Good to know!
          June 28, 2014, 04:44 PM #54
          Here's a couple more shots of the progress.
          Insta: @lelandSTI
            June 29, 2014, 09:10 AM #55
            evo1 Offline
            • Real Name: Mitch
            • Vehicle: 1992 Lancer Evolution RS, 6.7 SRW Mega Cab 3500
            • evo1 has no influence.
            Did you end up doing a Vibrant core?
              June 29, 2014, 09:16 AM #56
              Planbsti Offline
              • Real Name: Tony
              • Vehicle: 2007 Subaru Impreza WRX STI
              • Planbsti has no influence.
              Holy cow. Looking good!
              BMS STI
              boostfreak:pretty sure it's already illegal
                June 29, 2014, 02:57 PM #57
                Mitch, I ended up going with the treadstone tr1035 core with end tanks after all my research. Good value, good endtank design and great reviews.
                Insta: @lelandSTI
                  July 03, 2014, 09:44 PM #58
                  I can't wait until I can drive it!!! Ive been working on it relentlessly for the past 2 weeks because of the massive rains/flood that hit the prairies and have been unable to work. So what better to do than build my subi up!
                  Anyways, She is almost done now. I still have to hardwire the fuel pump once the STM kit arrives, and just a few other small things. But I spoke with Sunny (tuner) and looks like I can't get my tune done until August. Darn but no bigs.
                  Insta: @lelandSTI
                    July 07, 2014, 09:02 AM #59
                    Shes aliveeeeeee!!!!!!!
                    I spent the last 30 hours tracking down some stupid electrical issue, decided to just remove the wiring harness and reinstall. Sure enough it works like a beauty now! It fired right up with no leaks or anything. The EL headers and new turbo make this thing sound viscous. I was only able to drive out of boost and under 3.5 rpms as told by my tuner, but im hopin today after he looks at my logs I can maybe give her some gas! Its going to sound wild when it starts fully spooling.
                    Insta: @lelandSTI
                      July 07, 2014, 12:22 PM #60
                      evo1 Offline
                      • Real Name: Mitch
                      Amazing!
                        July 07, 2014, 03:50 PM #61
                        What's the benefit of having a rotated turbo on this kind of setup?   You did a solid job on the downpipe, looks great!
                          July 07, 2014, 04:40 PM #62
                          Thanks Dan.
                          It allows you to have a much wider range of turbo choices, larger intakes, smoother transitions, better up and down pipe geometry. Its also a lot easier to fit large turbos in the crammed engine bay with a rotated setup.
                          Insta: @lelandSTI
                            July 08, 2014, 11:39 AM #63
                            Here are some better pics of the build. Ill take some good ones of the car as a whole later this week hopefully. Its killing me not to drive it like I built it just yet  :P
                            Insta: @lelandSTI
                              July 12, 2014, 08:49 PM #64
                              I hit 5 psi the other day on my revised tune. :) anddddddd my car now sounds like a jet airplane. The HX35 screams, even at low boost such as that. Nothing beats the sound of a larger turbo spooling!
                              Drive by vid. Hit about 2 psi  :D
                              https://www.youtube.com/watch?v=6SNokh_hfIw&feature=youtu.be
                              Last Edit: July 12, 2014, 10:25 PM by I--RIDE--BIKES
                              Insta: @lelandSTI
                                July 30, 2014, 08:20 PM #65
                                I have been driving around on 14.5 psi for a couple weeks now and its been a blast.   I dont have time until spring to get to calgary for the dyno tune but im now working with Eric at Tourqed Performance to get me a map that lets this turbo breath!
                                I should have a fine tuned map by the end of this week. The car at 14.5 psi is just as quick as before. Im just too excited to see what it feels like with boost into the 20's.
                                Insta: @lelandSTI
                                  August 05, 2014, 11:13 AM #66
                                  In the last week I have been going and forth with Eric at Torqued Performance. We have created a safe yet fun map for me that hits 23psi. This little car is now a rocket ship! wow is all i can say.
                                  Here is a little clip of 1st-4th gear
                                  Last Edit: August 05, 2014, 08:18 PM by I--RIDE--BIKES
                                  Insta: @lelandSTI
                                    August 05, 2014, 05:52 PM #67
                                    SavageTaco Offline
                                    • Vehicle: Evo9 GG MR
                                    • SavageTaco has no influence.
                                    Really nice build. The car sounds great!
                                    Evo 9 aka "The Grinch" pump gas warrior
                                    Self tuned on an AEM V2
                                    2000 Aristo V300 - Daily
                                    "When in doubt run flat out"- C Mcrae
                                      August 05, 2014, 08:03 PM #68
                                      Get rid of the letter "s" in https.
                                        August 05, 2014, 08:22 PM #69
                                        Tanner20 Offline
                                        • Real Name: Tanner
                                        • Vehicle: 2006 Subaru STI
                                        • Tanner20 has no influence.
                                        where did you get you short block from?
                                          August 05, 2014, 08:25 PM #70
                                          Its an Outfront Motorsports Closed-deck block
                                          Insta: @lelandSTI
                                            August 05, 2014, 08:26 PM #71
                                            Tanner20 Offline
                                            • Real Name: Tanner
                                            thanks, nice build man great custom work.
                                              August 05, 2014, 08:34 PM #72
                                              Thanks! Im just glad its running like a champ. Im hoping to be able to make it to the FNL meet this friday too.
                                              Insta: @lelandSTI
                                                August 07, 2014, 07:45 PM #73
                                                Looks like i wont be called back to work just yet so ill be coming in for the FNL meet tomo.
                                                Insta: @lelandSTI
                                                  August 09, 2014, 11:55 PM #74
                                                  Well I'm super glad I was able to make it in for FNL. It was an awesome time and it was nice meeting some of you. I will definitely be coming in for more when I have time.
                                                  Insta: @lelandSTI
                                                    « Reply #74 on: August 09, 2014, 11:55 PM »
