Author Topic: Ctowns Stanced Celica/Bass Machine  (Read 25021 times)
May 09, 2017, 06:55 PM #475
Looks good!
    « Reply #475 on: May 09, 2017, 06:55 PM »
    May 12, 2017, 02:33 PM #476
    Got a decent amount of work done last night, started by taking off the intake and wiring harness to see if I could clean the block a little better with the degreasers and solvents, sadly little luck on that front. So I'm giving up for now.
    While I have the intake off I remembered i hadnt seen a plug for the knock sensor when I last had the loom on, so I started looking at my other two harness and remembered that the 00 - 02 use a 1pin knock sensor but the 02+ us a two pin. So I had to swap the knock sensor from my original motor over to the new motor. I couldn't find the plug because I was looking for a two pin plug... Also turns out that there is an interconnect between the wiring harness plug and the knock sensor plug for some odd reason. So I pulled the sensor off the old motor and then had to figure out how to remove the stud that holds the new style 2pin knock sensor from the new motor. Ended up using vice grips.
    20170511_225854 by Colin McAndrew, on Flickr
    20170511_230120 by Colin McAndrew, on Flickr
    20170511_230951 by Colin McAndrew, on Flickr
    20170511_231012 by Colin McAndrew, on Flickr
    20170511_231005 by Colin McAndrew, on Flickr
    20170511_231040 by Colin McAndrew, on Flickr
    Got the new old sensor in and torqued to spec.
      May 12, 2017, 02:57 PM #477
      I also decided to go ahead and paint the valve cover last night, having some second thoughts that I should have polished it.. but that would have been sooo much work, and I can always sand blast it off in the future if I really want. I also feel like the matte finish looked better... nothing is permanent though.
      20170511_205321 by Colin McAndrew, on Flickr
      20170511_213052 by Colin McAndrew, on Flickr
      20170511_221317 by Colin McAndrew, on Flickr
      20170511_224216 by Colin McAndrew, on Flickr
      20170511_232453 by Colin McAndrew, on Flickr
      20170511_234553 by Colin McAndrew, on Flickr
      20170512_005432 by Colin McAndrew, on Flickr
      20170512_082717 by Colin McAndrew, on Flickr
        May 12, 2017, 03:01 PM #478
        I also replaced the lift bolts (flange bolts) while I had the cover off and the gaskets of course. looks very extremely minimal wear on the cams so that inspires confidence. Between paint coats and getting high I tried out the aluminum polish I picked up. Made the intake look pretty darn good, still needs work though, I also only did one tube. Found out it also works on my works which is nice.
        Can you tell which one is polished?
        20170512_001048 by Colin McAndrew, on Flickr
        20170512_004501 by Colin McAndrew, on Flickr
        20170512_004616 by Colin McAndrew, on Flickr
        20170512_005127 by Colin McAndrew, on Flickr
        20170512_010546 by Colin McAndrew, on Flickr
          May 12, 2017, 03:17 PM #479
          Since the wiring harness I ordered is from a JDM Celica, it is lacking a speedo output, luckily I have two spares! So I started cutting and pulled a pin from the original harness and spliced it into the new harness. So much wiring work left to do to make this thing look really pretty, but I'm gonna focus on getting it running first.
          20170511_215431 by Colin McAndrew, on Flickr
          20170511_220102 by Colin McAndrew, on Flickr
          20170511_220351 by Colin McAndrew, on Flickr
          20170512_000558 by Colin McAndrew, on Flickr
          Bottom left portion of this pic is what I've done so far in works to clean it up.
            May 12, 2017, 03:19 PM #480
            Also test fitted my new group 31 battery, trunk is going to look a lot more "finished" this year.
            20170509_204350 by Colin McAndrew, on Flickr
            20170509_204354 by Colin McAndrew, on Flickr
              May 13, 2017, 12:05 PM #481
              Put the intake and starter back on the motor last night, also painted the motor mounts and finished polishing the intake.
              20170512_193648 by Colin McAndrew, on Flickr
              20170512_194223 by Colin McAndrew, on Flickr
              20170512_195455 by Colin McAndrew, on Flickr
              20170512_201327 by Colin McAndrew, on Flickr
                May 13, 2017, 02:04 PM #482
                Daaang that's shiny. Looks great
                  May 16, 2017, 04:29 PM #483
                  So this weekend and last night I spent more time cleaning and painting the engine bay, I'm pretty much happy with how it is and can finish up any more stuff when I complete the wire tuck and start shaving stuff.
                  20170514_150741 by Colin McAndrew, on Flickr
                  20170514_164607 by Colin McAndrew, on Flickr
                  20170515_193355 by Colin McAndrew, on Flickr
                  20170515_193400 by Colin McAndrew, on Flickr
                  I also did some more polishing on my wheels, this time I wet sanded with 2k then 3k then polish, it turned out much better than the first wheel I did so Im gonna have to redo that one. But thats okay, time spend is worth it.
                  20170514_205046 by Colin McAndrew, on Flickr
                  20170515_182831 by Colin McAndrew, on Flickr
                  I picked up some of the hoses and fittings I've been missing, only a few more vacuum lines need to be connected... but I honestly have no idea where they go yet haha.
                  20170515_182149 by Colin McAndrew, on Flickr
                  Last night the engine pan miraculously fell off the motor. But seriously it was huge pain breaking that old seal, more like glue than a gasket. Also kinda concerned because I drained close to 5 litres of oil out of the motor, and its only supposed to hold 4.4L. So its got me thinking either someone just overfilled it and hopefully theres no damage to seals or gaskets internally, or they over fill it on purpose because it burns oil? I sure hope not :'( there was no coolant in the oil though, and no oil in the coolant so I'm hopeful.
                  Anyway I cleaned off the old gasket and painted the pan a pretty gloss black, then re installed it. Looks nice and clean in side at least. No signs of aluminum dust in the oil or anything like that.
                  20170515_202849 by Colin McAndrew, on Flickr
                  20170515_202853 by Colin McAndrew, on Flickr
                  20170515_203330 by Colin McAndrew, on Flickr
                  20170515_203633 by Colin McAndrew, on Flickr
                  20170515_204426 by Colin McAndrew, on Flickr
                  20170515_214039 by Colin McAndrew, on Flickr
                  20170515_214217 by Colin McAndrew, on Flickr
                  20170516_003047 by Colin McAndrew, on Flickr
                  20170516_011637 by Colin McAndrew, on Flickr
                  Mmm fresh filter.
                    May 16, 2017, 04:56 PM #484
                    Also decided it was time to put the exhaust manifold on, to do so I had to replace the old gasket obviously, but the manifold is designed to block off these 4 holes on the back of the block that are directly above the exhaust ports for the air injection system that was introduced in 03, I don't need these nor did this motor ever need them. So the old gasket blocked these ports, but the new gasket only does the actual ports, I had planned for this though and had a "block off kit" I got from the company I got the JDM engine harness from. basically its a tap and 4 plugs so you can thread the holes and insert the plugs. All went well until the tap decided to snap.
                    20170515_223459 by Colin McAndrew, on Flickr
                    20170515_224143 by Colin McAndrew, on Flickr
                    20170515_224311 by Colin McAndrew, on Flickr
                    20170515_225814 by Colin McAndrew, on Flickr
                    I was pretty rattled when it snapped but I took a deep breath and started brain storming. Ended up using a hardened punch to gently tap the tap in a counter clockwise direction until it spun out. Luckily I had another tap that was the same thread and was able to finish the rest with no issues.
                    20170515_233241 by Colin McAndrew, on Flickr
                    20170515_233615 by Colin McAndrew, on Flickr
                    Pardon the terrible quality on then next few photos, the lighting in the corner of my garage isn't great.
                    Anyway, the header was pretty dirty and while I was busting off what was left of the old gasket I noticed that there is a fairly large lip inside the port of the manifold that has no real reason to be there. So I grabbed a grinding wheel and ground it down a bunch and removed a bunch of the old carbon build up. Call it a half assed port and polish. I don't know if it will make any difference but I highly doubt it will hurt either.
                    20170515_221757 by Colin McAndrew, on Flickr
                    20170515_221800 by Colin McAndrew, on Flickr
                    20170515_221932 by Colin McAndrew, on Flickr
                    20170515_221938 by Colin McAndrew, on Flickr
                    20170515_222828 by Colin McAndrew, on Flickr
                    20170515_222833 by Colin McAndrew, on Flickr
                    20170515_222838 by Colin McAndrew, on Flickr
                    20170515_234337 by Colin McAndrew, on Flickr
                      May 16, 2017, 06:35 PM #485
                      Always annoys me when bolts/various things snap like that. Glad it came.oit easy for ya.
                        May 17, 2017, 10:36 AM #486
                        Had another late night last night, I spent some time just staring at the car, trying to decide if there was anything left to do before I put the motor back in, I came to the conclusion that there was not. So last night I put the new motor in.
                        20170516_191411 by Colin McAndrew, on Flickr
                        20170516_192046 by Colin McAndrew, on Flickr
                        20170516_192839 by Colin McAndrew, on Flickr
                        20170516_193818 by Colin McAndrew, on Flickr
                        20170516_221649 by Colin McAndrew, on Flickr
                        20170516_221654 by Colin McAndrew, on Flickr
                        20170516_221702 by Colin McAndrew, on Flickr
                        20170516_233905 by Colin McAndrew, on Flickr
                        20170516_233909 by Colin McAndrew, on Flickr
                        20170516_235859 by Colin McAndrew, on Flickr
                        20170517_000728 by Colin McAndrew, on Flickr
                        All the wiring plugged into the car side of the fuse box as it should so that was nice. I started putting stuff back on the motor as well, the ac compressor is mounted, the clutch slave cylinder, the heater core hoses are in place, as seen in the pictures, the GT hose was not long enough, good thing I bought the GTS one in advance. I hope to get the motor fired up tonight, I didn't have plugs for it and felt I might as well replace them. I'm not great with colouring so could someone tell me if the plugs look normal? Parts I still need to pick up, some coolant, tranny fluid, new plugs and some hand moisturizer.
                        20170516_234104 by Colin McAndrew, on Flickr
                        Since the throttle body on the GTS is about .5" larger than the GT I need a new intake, turns out the ebay intake I bought previously for the car that didnt fit, was actually for the GTS, so I think I can find a way to make this work for the time being. I want to get a polished intake, but the matte black actually goes nice with the intake.
                        20170516_234450 by Colin McAndrew, on Flickr
                        I would have kept working on this last night but for starters I was almost falling asleep laying under the car trying to put the power steering pump back in place, and this is when mistakes are made. Plus I was having a hecking time trying to get the pump in, the two mounts where it bolts on are the slightest bit to close together, seems to be the kind of mount where there is a steel sleeve in the mount that should move a bit but doesn't want to move. Might have to file it down till it fits, but I'll worry about that tonight.
                        Last Edit: May 17, 2017, 10:58 AM by Ctown8
                          May 18, 2017, 09:55 AM #487
                          Last night got some work done, no pics of progress, nothing to really see anyway.
                          Filled the engine and trans oil, put the axles in, wheels are back on, power steering is back in place, alternator is in, new spark plugs are in. Put the belt I had ordered on and it seems to be too long, I double and triple checked the routing and I really don't know why it doesn't fit. The part number on the belt matches what everyone on the forums says to get, but who knows. I'm hoping part source has a belt thats the same but 1 or 2 inches shorter.
                          I've figured out where the majority of vacuum and coolant lines go, just one or two more that I'm unsure of.
                          Gotta do a little more cleaning and touch up a couple paint scratches that occurred while putting the motor in, then put the rad fans in and connect the rest of the coolant lines, then put the ecu in and hope she starts.
                            May 20, 2017, 04:59 PM #488
                            Touched up the paint on a couple pieces that were barely painted originally, not a noticeable piece but it comforts me to know that if someone looks close its nice and painted haha.
                            20170518_225105 by Colin McAndrew, on Flickr
                            Got the coolant overflow tank installed, rad support and rad fans, made a couple more vacuum connections, apparently one of the ones I was worried about doesn't actually matter and can just be plugged. Also figured out where the rest of the coolant lines went, I think.. this could explain another problem I'm having, uncertain at this point and need to fix other stuff first.
                            20170518_231808 by Colin McAndrew, on Flickr
                            20170518_231816 by Colin McAndrew, on Flickr
                            20170518_235021 by Colin McAndrew, on Flickr
                            As of last night I connected power. And she fired up after a couple cranks and sputters!
                            20170519_191805 by Colin McAndrew, on Flickr
                            I still need to finish bleeding the coolant, but I have a bigger problem to deal with first, my idle is sitting at 2k for some reason. I figure its because the stupid iacv is gunked tf up and has seized, I had already tried to clean it before but judging by the amount of crud that was in there its not going to cut it. So I ordered a new on today and will have it early next week. I also think I have the bleeder hose off the block coming from the wrong port and needs to be switched with the one for the iacv, but should matter for idle because its only a temperature thing, not flow.
                            Other thing that bugging me but isnt necessarily an issue, when bleeding the coolant, I'm supposed to leave a cap off on the reservoir and watch the fluid that goes through, at first it came out slow and I could see bubbles coming through the line, but eventually they stopped and it was like pressure built up and it wanted to over flow so I capped it. Then I had to remove some coolant because it was over the fill line. I put the reservoir back to normal height and ran the motor for a while, I had to add some coolant. This was all okay but the only time the fans came on was when I first stated and it got a smidge hotter than normal, so I shut it off and added more coolant, then it was fine and stayed at the mid temp where it should be. But the fans never came on after and that concerned me a little. Thinking maybe the thermostat is staying open and its efficient enough to keep cool that way? I'll have to do lots more trouble shooting to narrow down the kinks.
                            But the good news is it runs, and thats a start. hehe pun not intended.
                              May 24, 2017, 01:26 PM #489
                              I started this a while ago but hadn't made any real progress until the last couple days.
                              Relocating the battery to the trunk as part of the wire tuck, this meant I had to run a new power wire directly from the battery to alt up front. I had already done this previously but I had a distro point on my battery terminal so the wire was made up of three pieces including the fused area, so I wanted it to be direct, plus a fuse of course, and my wire was not long enough. So I ran a new power wire last night, which was a pita, I don't have much skin left on my hand today from shoving my hand in a tight space to pull slack through on my power cable at a certain angle so it wouldn't catch on the enclosure. That wire is now run, and loomed/techflexxed.
                              Since the battery is going in the trunk it needs to be secured properly, so on sunday/monday I spent my time making a box to hold the battery, and a false floor to secure to the spare tire holder and then secure the battery box to that, and brace it forward against the rear strut brace.
                              20170521_232525 by Colin McAndrew, on Flickr
                              20170521_232452 by Colin McAndrew, on Flickr
                              20170522_112415 by Colin McAndrew, on Flickr
                              20170522_112751 by Colin McAndrew, on Flickr
                              20170522_112802 by Colin McAndrew, on Flickr
                              20170522_134956 by Colin McAndrew, on Flickr
                              20170522_135830 by Colin McAndrew, on Flickr
                              20170522_174611 by Colin McAndrew, on Flickr
                              20170522_190000 by Colin McAndrew, on Flickr
                              20170522_190004 by Colin McAndrew, on Flickr
                              Perfect fit
                              20170522_190015 by Colin McAndrew, on Flickr
                              20170522_202516 by Colin McAndrew, on Flickr
                              20170522_202521 by Colin McAndrew, on Flickr
                              20170522_202530 by Colin McAndrew, on Flickr
                                May 24, 2017, 01:57 PM #490
                                I've decided to simply hide the speaker amp, its not much to see and the speaker wires are pretty short, so I will mount it where it used to be, but mounted properly and then covered by a shelf. I made up the mount last night and mounted the amp, next I need to mount the subwoofer amplifier, then build up the supports around the amp to support the floor, and figure out how to support the plexi window for the amplifier.
                                20170523_214209 by Colin McAndrew, on Flickr
                                20170523_215249 by Colin McAndrew, on Flickr
                                20170523_221405 by Colin McAndrew, on Flickr
                                Now I'm running low on wood and scraps from my garage wont cut it anymore... pun not intended.
                                And this sexy tech flexxed power wire that no one will see when I'm done
                                20170523_204846 by Colin McAndrew, on Flickr
                                Last Edit: May 24, 2017, 02:18 PM by Ctown8
                                  May 27, 2017, 09:36 AM #491
                                  Some killer progress man. Love how the polished and red looks together. Perfect combo.
                                    May 27, 2017, 09:41 AM #492
                                    Thanks man, still lots left to do, I've been up till around 3 everyday for the last couple weeks cramming. Big update soon.
                                      May 29, 2017, 08:46 AM #493
                                      Damn this thing was bumpin yesterday at SA. Great work Colin!
                                        May 29, 2017, 09:33 AM #494
                                        Thanks Igor, I'm pretty proud of all the work I've put into her!
                                          May 29, 2017, 04:48 PM #495
                                          I fully installed my intake (added the lower portion in the fender and some hose clamps) and I'm actually pretty happy with how it looks, the black kinda matches other parts of the bay. In the future I want an AEM Venom, which is basically what I have except polished and a lil thicker.
                                          20170524_225848 by Colin McAndrew, on Flickr
                                          For the audio system in the back I spend a stupid amount of hours on it this last week in order to finish it before spring awakening, but I did finish, and I'm happy with how it turned out.. except for the fact that we ran out of suede at work so I had to use carpet :(
                                          I figured out my overall trunk height, realized the old floor supports were too high and chopped them out.
                                          20170523_225501 by Colin McAndrew, on Flickr
                                          20170524_215722 by Colin McAndrew, on Flickr
                                          Before proceeding with more wood cutting I had to determine where my wires would run and how I would organize them. Took me longer than it should have but hey, it was 3am afterall.
                                          I must say I love techflex and the finished look it gives wiring, I didn't cover all my wires, but I did most of them. I might go back one day and do the rest, but this is stuff really only I see anyway.
                                          Also turns out after looking back now, I never took a finished picture of the wiring under the floor all tied up and secured. But you get the idea.
                                          20170525_000059 by Colin McAndrew, on Flickr
                                          20170525_013052 by Colin McAndrew, on Flickr
                                          20170525_231711 by Colin McAndrew, on Flickr
                                          20170526_002931 by Colin McAndrew, on Flickr
                                          20170525_183831 by Colin McAndrew, on Flickr
                                          Terminated the charging wire on the alternator and damn I think it looks awesome. Something about that blue peeking through the gaps in teh tech flex gives it such a neat look.
                                          20170525_021410 by Colin McAndrew, on Flickr
                                            May 29, 2017, 04:52 PM #496
                                            I need a new throttle cable, this did fine for the day though. Also my idle is good now, but after this pic was taken, the next day when I fired it up I got a code for evap and its been doing some odd stuff. But I'll figure it out.
                                            20170525_030857 by Colin McAndrew, on Flickr
                                            20170525_193654 by Colin McAndrew, on Flickr
                                            Got my license plates on too, wasnt sure on location, what do you think?
                                            20170526_010003 by Colin McAndrew, on Flickr
                                            20170526_184752 by Colin McAndrew, on Flickr
                                            20170526_185259 by Colin McAndrew, on Flickr
                                            And I got myself some new lugs to replace my crusty old ones, not a good pic and no mounted pics yet though.
                                            20170526_182026 by Colin McAndrew, on Flickr
                                            Last Edit: May 29, 2017, 04:56 PM by Ctown8
                                              May 29, 2017, 04:59 PM #497
                                              Mounting an amp upside down is tricky, and I might redo this, but it works and is solid.
                                              20170525_200812 by Colin McAndrew, on Flickr
                                              20170525_210012 by Colin McAndrew, on Flickr
                                              20170525_211301 by Colin McAndrew, on Flickr
                                              20170525_215210 by Colin McAndrew, on Flickr
                                              20170525_215217 by Colin McAndrew, on Flickr
                                              20170525_224654 by Colin McAndrew, on Flickr
                                              20170525_223921 by Colin McAndrew, on Flickr
                                              20170525_223929 by Colin McAndrew, on Flickr
                                              20170526_203427 by Colin McAndrew, on Flickr
                                                May 30, 2017, 08:34 AM #498
                                                Second location for front plate.
                                                  May 30, 2017, 11:46 AM #499
                                                  And thats where it is
                                                  Got the amp mount made up and secured to the subfloor, she aint going anywhere! Then I started making the cover for the amp and battery, and then the sides which are my least favorite thing to do, but they turned out good anyway. As you can see the fitment at first wasn't perfect, but after some trimming with a file they fit pretty much perfectly. Just a little dissapointed i had to use carpet, once we get more suede I'll redo them at the same time I do the plexi and leds.
                                                  20170526_212351 by Colin McAndrew, on Flickr
                                                  20170526_220809 by Colin McAndrew, on Flickr
                                                  20170526_223323 by Colin McAndrew, on Flickr
                                                  20170526_224010 by Colin McAndrew, on Flickr
                                                  20170526_224018 by Colin McAndrew, on Flickr
                                                  20170526_232032 by Colin McAndrew, on Flickr
                                                  20170526_235946 by Colin McAndrew, on Flickr
                                                  20170527_221001 by Colin McAndrew, on Flickr
                                                  20170527_223655 by Colin McAndrew, on Flickr
                                                    « Reply #499 on: May 30, 2017, 11:46 AM »
