Author Topic: Ctowns Stanced Celica/Bass Machine  (Read 25853 times)
May 30, 2017, 12:18 PM #500
Finalizing the fit and finish at 2am, cause when eles would you do it?
20170527_224737 by Colin McAndrew, on Flickr
20170527_224740 by Colin McAndrew, on Flickr
20170528_001336 by Colin McAndrew, on Flickr
20170528_002341 by Colin McAndrew, on Flickr
20170528_003624 by Colin McAndrew, on Flickr
20170528_004016 by Colin McAndrew, on Flickr
20170528_012814 by Colin McAndrew, on Flickr
20170528_015506 by Colin McAndrew, on Flickr
20170528_015515 by Colin McAndrew, on Flickr
20170528_023536 by Colin McAndrew, on Flickr
2017-05-30_12-12-03 by Colin McAndrew, on Flickr
    « Reply #500 on: May 30, 2017, 12:18 PM »
    May 30, 2017, 01:57 PM #501
    To fix one of my check engine lights I added a sensor that I was told I didn't need, I've yet to do a proper test drive, but I started it up and took it down my road and back last night and I didn't get a code for either of the two I had before, and its supposed to run test within 10 seconds of starting so fingers crossed its fixed. It s a good thing I have two parts harness's.
    20170529_210725 by Colin McAndrew, on Flickr
    20170529_210801 by Colin McAndrew, on Flickr
    20170529_211358 by Colin McAndrew, on Flickr
      May 30, 2017, 02:02 PM #502
      I also sanded and clear coated my lights before spring awakening, something weird happened with the clear though and it has a sort of fog to it, so I'll need to redo it, not sure why it happened maybe I used the wrong clear.. I dunno.
      20170527_020307 by Colin McAndrew, on Flickr
      20170527_024019 by [url=https://flic.kr/p/TZSjVu]20170527_223819 by Colin McAndrew, on FlickrColin McAndrew[/url], on Flickr
        May 30, 2017, 02:06 PM #503
        And here some banger pics from Spring Awakening
        Untitled by Noah Cormack, on Flickr
        RRR_6228 by Emmanuel Siguenza, on Flickr
        RRR_6038 by Emmanuel Siguenza, on Flickr
        Last Edit: May 30, 2017, 02:16 PM by Ctown8
          May 30, 2017, 02:52 PM #504
          The fog could have been temperature related. I had issues when I painted my side skirts with the clear becoming hazy. I believe it was too humid when i did it.
            June 01, 2017, 12:11 PM #505
            So since I'm going to have an 8400rpm redline (once I work out these bugs) I figured i should get the GTS cluster since it has a higher redline and speedo too. But I've never been a big fan of the grey they use in the cluster (even though its probably for a good reason like glare or something silly) so I decided to change it!
            I wont be sanding the surface smooth or clear coating, I'm just gonna leave it as is because it think the rough surface will be better for sun etc.
            20170530_205258 by Colin McAndrew, on Flickr
            20170530_205311 by Colin McAndrew, on Flickr
            20170530_205425 by Colin McAndrew, on Flickr
            20170530_211519 by Colin McAndrew, on Flickr
            20170530_235436 by Colin McAndrew, on Flickr
            20170530_235652 by Colin McAndrew, on Flickr
              July 18, 2017, 10:57 AM #506
              Finally got around to lighting up the amplifier and covering it with plexy. I will be redoing the lights though because I'm not satisfied with how they turned out, it will either be simply relocating them or I might try to do something layered with some edge lit plexy.
              Anyway, heres some pics of the progress.
              20170628_205709 by Colin McAndrew, on Flickr
              20170628_213851 by Colin McAndrew, on Flickr
              20170702_231005 by Colin McAndrew, on Flickr
              20170702_234734 by Colin McAndrew, on Flickr
              20170702_234759 by Colin McAndrew, on Flickr
              20170702_234803 by Colin McAndrew, on Flickr
              20170703_000516 by Colin McAndrew, on Flickr
              20170703_002410 by Colin McAndrew, on Flickr
              20170703_183710 by Colin McAndrew, on Flickr
              20170703_185624 by Colin McAndrew, on Flickr
              20170703_184720 by Colin McAndrew, on Flickr
              20170703_195657 by Colin McAndrew, on Flickr
              Wondering if anyone got a picture of the trunk set up while at driven? I didnt take the plexi cover off until I got to Driven.
              Last Edit: July 18, 2017, 11:09 AM by Ctown8
                July 18, 2017, 11:00 AM #507
                Swapped out my cluster with the one from the GTS donor car, no more comic sans fonts for my bbg <3
                20170707_161635 by Colin McAndrew, on Flickr
                20170707_162136 by Colin McAndrew, on Flickr
                  July 18, 2017, 11:06 AM #508
                  Other Driven prep things, actually maxed my coils short of removing collars. Kinda disappointed, thought they'd be lower...
                  20170707_165727 by Colin McAndrew, on Flickr
                  After a couple years I finally got around to properly installing my bass knob. I actually find its not as easy to use where it is now because I have to reach for it, but its not bad, and look 10x better than having it stuck to the side of my console!
                  20170703_012133 by Colin McAndrew, on Flickr
                  Quick bug removal and wax job and she was ready for Driven.
                  20170703_213505 by Colin McAndrew, on Flickr
                    July 18, 2017, 11:50 AM #509
                    Super proud to take home Best in Show Ice at Driven 2017!
                    2017-07-18_11-17-07 by Colin McAndrew, on Flickr
                    It feels great when hard work pays off  :banana:
                      August 04, 2017, 10:20 AM #510
                      Small update, replaced the knock sensor, had to take out the darn intake to do it, but its done. Found two different torque specs for it, 29ft/lbs, and 33ft/lbs. I torqued it to 33, then after i finished i found another page saying 29, so now I'm worried that its too tight and might be why I was having issues before with the old sensor. best case its works, intermediate would be I just need to loosen it, worst case would be I damaged the sensor and need another.
                      20170801_212523 by Colin McAndrew, on Flickr
                      I also tried to install a Hondata intake spacer/gasket that supposed to help keep the intake cooler by separating the metal surfaces, it didn't fit though, and I couldn't bolt the intake back on with it in place. Kinda unhappy about that but whatever. I'll complain to hondata and see what happens..
                      20170801_212518 by Colin McAndrew, on Flickr
                        August 04, 2017, 12:22 PM #511
                        To my knowledge(limited at best), knock sensors are a series piezocrystals and springs and stuff that are tuned to "listen" to certain frequencies. Those frequencies are your knock events. As the engine vibrates the piezo creates voltage which tells the ECU that there is knock, and to pull timing. The threads in the block are typically just to hold it and should have no effect on how it operates within a few lb/ft's of torque spec. Only a loose one would possibly cause issues.
                        Again, to my knowledge
                          August 04, 2017, 12:55 PM #512
                          What I read said that if its too tight it could set off false knock events and pull timing, but the error code I'm getting sounds more like the sensor wasn't communicating with the ecu at all, so well find out tonight after I bleed the coolant system and test drive it.
                            August 19, 2017, 10:25 AM #513
                            Couple more pics from Driven, also the new knock sensor fixed my CEL, now I just have to figure out the P0450 and then no more CEL's!!
                            Driven and Paws to the Pedal 2017 by Colin McAndrew, on Flickr
                            Chrissy and Shannon by Colin McAndrew, on Flickr
                              « Reply #513 on: August 19, 2017, 10:25 AM »
