Author Topic: Brian Reimer Audio Installs  (Read 11321 times)
June 09, 2014, 11:24 AM #25
BRAUDIO Offline
  • Real Name: Colin
  • Vehicle: Nissan NV2500 x2, Old Astro
  • BRAUDIO has no influence.
Installed These subs and this amp in this nice 2013 300, hid the amp under the rear deck, and used the factory carpet to cover it, it looked completely stock when we were done, but sadly we took no more pictures. the box fit perfect between the rear wheel wells.
Brian Reimer Audio. For all your Home and Car audio needs.
Pioneer, Focal, Hertz, Illusion Audio, Mosconi, Gladen, JVC, CompuStar, Parrot, Wirez, Clarion, Samsung, Panasonic, Definitive, Boston, Sinclair.
    « Reply #25 on: June 09, 2014, 11:24 AM »
    June 11, 2014, 08:35 AM #26
    Yurek Offline
    • Real Name: Tony
    • Vehicle: '92 Soarer x2, '92 SC300, '97 Civic, '98 Soarer
    • Yurek has no influence.
    Very nice work Colin! Impressive. :) Are you able to message me some typical price ranges for some of these installs? I understand every vehicle system install is different depending on what the customer is requesting, but just a rough ball park figure? Thanks! Keep up the great work!
    1/4 ET 15.7650 @ 95.14 MPH
      June 14, 2014, 08:37 AM #27
      Bmoney Offline
      • Real Name: Bmoney
      • Bmoney has no influence.
      am I seeing things?  Or does that car not even fit in the bay?  :)
        June 14, 2014, 09:22 AM #28
        BRAUDIO Offline
        • Real Name: Colin
        Nope, haha a lot of vehicles don't fit, its not a big deal with this nice weather, but in winter we have another bay at Brian's house where we take trucks and larger cars.
          June 14, 2014, 09:29 AM #29
          BRAUDIO Offline
          • Real Name: Colin
          Proper wiring harness
            June 14, 2014, 09:55 AM #30
            Bmoney Offline
            • Real Name: Bmoney
            that sucks
              June 14, 2014, 11:02 AM #31
              Ford/mazda adapter ;)
              Nice to see people are still using heat shrink.   I hate it when i see an electrical taped connection ><
                June 14, 2014, 12:50 PM #32
                ET FTW Danny boy ;)
                  June 14, 2014, 02:11 PM #33
                  Originally posted by CFMP RAblue
                  ET FTW Danny boy ;)
                  ima smack you buddy....
                    June 14, 2014, 07:40 PM #34
                    Bmoney Offline
                    • Real Name: Bmoney
                    how do you know its a Ford/Mazda harness?  I see the radio end - but not the vehicle side...unless I'm blind?
                      June 14, 2014, 08:09 PM #35
                      suubinoob Offline
                      • Real Name: Clayton
                      • Vehicle: secret project,Locomotive,2014 RAM
                      • suubinoob has no influence.
                      the red connector im assuming in the top
                      Choo Choo
                        June 14, 2014, 09:54 PM #36
                        Bmoney Offline
                        • Real Name: Bmoney
                        depending on the brand of harness, there are several that are red, not just Ford/Mazda ;)  Be cool if it was tho.
                          June 14, 2014, 10:21 PM #37
                          based on wire combination and the size of the connector, it does look like it.  I have one sitting in the garage.  Ford and Mazda used the same connector on most of the head units.     I could be wrong, but it does look like it.
                            June 14, 2014, 10:23 PM #38
                            Bmoney Offline
                            • Real Name: Bmoney
                            the wire combination is familiar since they are typical EIA color standards  :)
                              June 14, 2014, 10:30 PM #39
                              Too true LOL.  I forgot about that.
                                June 16, 2014, 09:13 AM #40
                                BRAUDIO Offline
                                • Real Name: Colin
                                Enough already! Its from an 06 Mazda 3!
                                  June 16, 2014, 12:45 PM #41
                                  Scorp Offline
                                  • Real Name: Professional Forum Lurker
                                  • Vehicle: '10 Gencoupe
                                  • Reputation Power: 12
                                  • Scorp has no influence.
                                  How much to stuff my doors with underwear and socks for sound deadening?
                                  Everything that kills me, makes me feel alive.
                                    June 16, 2014, 01:03 PM #42
                                    BRAUDIO Offline
                                    • Real Name: Colin
                                    your under wear or ours? and you cant stuff door, that would block the windows, only certain panels!
                                    Last Edit: June 16, 2014, 01:04 PM by BRAUDIO
                                      June 16, 2014, 10:54 PM #43
                                      Bmoney Offline
                                      • Real Name: Bmoney
                                      lol.  at some point you'll realize traffic in YOUR threads is a good thing.  ;)
                                        June 18, 2014, 09:33 AM #44
                                        BRAUDIO Offline
                                        • Real Name: Colin
                                        This is true :p
                                          June 18, 2014, 05:29 PM #45
                                          BRAUDIO Offline
                                          • Real Name: Colin
                                          02 BMW jl components in the front, something else in the rears, two jl amps, pioneer DEH-80PRS.
                                          Last Edit: June 18, 2014, 05:35 PM by BRAUDIO
                                            June 23, 2014, 07:15 AM #46
                                            STI LOL Offline
                                            • Vehicle: truck.
                                            • STI LOL has no influence.
                                            +1 for your installs! I bought my A4 with a setup from you guys and the workmanship on hiding all components neatly is definately nicest ive seen yet. The boston components sound phenominal. Not one bad thing to say about my 14.1 boston/audi setup!
                                            If these boys try talk you into a BOSTON sub to get "clean" not shake your licence plate off your car sound, listen. I was always into the 2x12's highschool stage, now that i'm in the more "expensive" game with subs, 1 10" is more than enough and sounds unbelievable! Ask anyone whos been in my car!
                                              June 25, 2014, 10:53 AM #47
                                              BRAUDIO Offline
                                              • Real Name: Colin
                                              91 Mustang Pioneer DEH-99PRS head unit, Diamond Audio Subwoofer, STEG amplifiers, 0awg wiring, Focal Components, Maaaasive Super Charger and More.
                                              Last Edit: June 25, 2014, 10:55 AM by BRAUDIO
                                                June 25, 2014, 10:58 AM #48
                                                BRAUDIO Offline
                                                • Real Name: Colin
                                                2007 Ram 1500 JVC head unit, and Hertz 6x9's. The Deck looks like its not in properly because the trim wasn't fully attached yet.
                                                Last Edit: June 25, 2014, 11:24 AM by BRAUDIO
                                                  June 25, 2014, 11:00 AM #49
                                                  BRAUDIO Offline
                                                  • Real Name: Colin
                                                  And heres a sneak peak of my build :)  :banana:
                                                    « Reply #49 on: June 25, 2014, 11:00 AM »
