Author Topic: DIY: Retrofiting Aftermarket USB Cable  (Read 909 times)
May 11, 2014, 07:35 PM #0
DhiJay23 Offline
  • Vehicle: 2011 Mitsubishi RVR
  • DhiJay23 has no influence.
I want to make my RVR as neat as possible regarding to cables and wiring. This was done so that I could retrofit the USB from the aftermarket radio to where the factory was. Loose cables from my glovebox really gets into me. :rolleyes: Im gonna try to explain it as clear as I can since English is not my mother tongue, So bare with me guys. :D
Tools needed: USB Cable, Phillips head screwdriver, Wire Stripper. Soldering Iron, Electrical Tape and Prying tool.So this is my first DIY and I hoping to contribute to the OS community and thanks to cadilak78 for the tips how to removed the centerpiece trim.
1st: Remove the trim. Just follow this thread.DIY: Interior Trim Vinyl Wrap
2nd:  Once the trim piece is removed, There's another trim that needs to be remove to locate the connections of the USB,12V and the AUX Inputs in the armrest box. There's 4 screws that needs to remove. (Sorry I forgot to take a picture. Just use the image above)
3rd: Once all the trims removed, You can see the connections are all exposed. Remove this connector that connects to factory USB
4th: I know its bad to cut the original wiring but since I want everything wiring to be neat and I know its not gonna ruin any major connection I cut this wire that connects to the factory USB. Here's what inside the factory connector.
5th: Cut the Male USB cable and here's what inside.
6th: Connect the two cables together and here what your wiring should look like.
7th: Secure all connections and solder it together. I ran out of heat shrink so I used electrical tape on each wire connection and taped it again altogether.
8th: Connect the two USB and and start hiding the cable. I start mine from here all the way to the center.
9th: Reconnect this connector. (forgot to take pictures again)
10th: Start putting the trim pieces back together and Enjoy.
I hope this helps! If you have any questions feel free to ask. I'll help out any way I can.
Last Edit: May 11, 2014, 09:52 PM by DhiJay23
    « on: May 11, 2014, 07:35 PM »
    May 11, 2014, 07:37 PM #1
    • Reputation Power: 205
    Solid write up. I'd check the connection before reassembly though
      May 11, 2014, 09:54 PM #2
      DhiJay23 Offline
      Okay. Hope it helps.
        « Reply #2 on: May 11, 2014, 09:54 PM »
