Author Topic: What did you do to your car today? part 2  (Read 190845 times)
May 16, 2017, 10:02 AM #2875
  • Reputation Power: 205
Drove it, Found another problem. Starred at it in disgust for an extended period of time.
    « Reply #2875 on: May 16, 2017, 10:02 AM »
    May 16, 2017, 10:25 AM #2876
    • Reputation Power: 246
    more wheel bearings?
      May 16, 2017, 10:28 AM #2877
      • Reputation Power: 120
      this.
        May 16, 2017, 11:00 AM #2878
        Originally posted by Ctown8
        this.
        Not Yet, but when that happens I'm going to drive it until catastrophic failure occurs and runs it straight into a wall.
          May 16, 2017, 01:52 PM #2879
          Originally posted by Magner
          Bring it out to an auto-x this summer, I want to see you take on a Focus RS that's joined this year!
          Edit: That thing sounds like a good match for the rest of us in SMF, come try to take Coach's lunch money like old times.
          At some point I intend to.
            May 16, 2017, 07:53 PM #2880
            Shier Offline
            • Real Name: Greg
            • Reputation Power: 56
            Installed my Cobb air box today. Quiets the intake down just enough to not be overly loud anymore
              May 16, 2017, 09:07 PM #2881
              MarvinM10 Offline
              • Real Name: Ed
              • Vehicle: 2010 Mazdaspeed3
              • Reputation Power: 27
              • MarvinM10 barely matters.MarvinM10 barely matters.
              Installed spark plugs. The old ones were in good shape, no bad wear indications.  :)
              Laziness breeds efficiency
                May 17, 2017, 09:20 AM #2882
                unpulled the motor
                  May 20, 2017, 08:37 AM #2883
                  Got an alignment for it
                    May 20, 2017, 09:37 AM #2884
                    Started it.  :alien:
                      May 23, 2017, 06:58 PM #2885
                      Shier Offline
                      • Real Name: Greg
                      Installed Cobb short shifter and Perrin reverse lock out.
                        May 23, 2017, 08:39 PM #2886
                        How do you like the short shifter?
                          May 23, 2017, 08:41 PM #2887
                          Shier Offline
                          • Real Name: Greg
                          pretty good so far, gotta do the bushings next, just ran out of time. Looked at where they are and I don't look forward to that job either.
                            May 24, 2017, 09:26 AM #2888
                            Ran new 1/0 power cable from alt to batt in trunk. Its a lot harder when theres a box in the car already and you have to pull the new cable under it. Also worked on the amp rack in the trunk, I hope I finish by this sunday.
                              May 24, 2017, 11:58 AM #2889
                              After hearing about how big of a pain they were to install I just sold mine haha.
                                May 24, 2017, 03:04 PM #2890
                                Shier Offline
                                • Real Name: Greg
                                I thought about it, but I could see how cracked and chewed up my stock bushings already are
                                  May 24, 2017, 05:17 PM #2891
                                  Picked my car up from Winters. Don't have to clean the interior because they did it for me woo :banana:
                                    May 25, 2017, 11:39 PM #2892
                                    Supra2jz94 Offline
                                    • Vehicle: Toyota supra 2jz
                                    • Supra2jz94 has no influence.
                                    Dropped my Supra off at speedfactor, for a single turbo install, ordered some v band clamps and a jdm front cat delete downpipe.
                                      May 26, 2017, 12:27 AM #2893
                                      Recently I have installed a FSWerks short shifter plate, bigger FMIC, and a Mountune front splitter.
                                        May 26, 2017, 08:53 AM #2894
                                        J_mullet Offline
                                        • J_mullet has no influence.
                                        Been awhile since I posted here. This spring I converted my G35 from Auto to stick, got an ecu tune and random other tinkering.
                                          May 26, 2017, 12:32 PM #2895
                                          How hard was that
                                            May 26, 2017, 12:37 PM #2896
                                            J_mullet Offline
                                            How hard was that
                                            Hardest part was getting the clutch pedal mounted and dealing with the pilot bushing. Took about 2 weeks of tinkering a few hours a day. Did it solo, without a hoist. If you can change a clutch, you can do this.
                                              May 26, 2017, 12:39 PM #2897
                                              That's a pretty big task. Nice job.
                                                May 26, 2017, 12:46 PM #2898
                                                When you need more, call me.   USA has insane pricing.
                                                  May 26, 2017, 01:33 PM #2899
                                                  Fixed idle issue with new iacv :)
                                                    « Reply #2899 on: May 26, 2017, 01:33 PM »
