Author Topic: DRL low beams problem.  (Read 1187 times)
August 20, 2014, 06:31 AM #0
yathots Offline
  • Real Name: James
  • Vehicle: 2009 Mitsubishi Lancer DE
  • yathots has no influence.
I have a problem with my low beams (drl) for my 09 lancer. They don't work at all when the engine is running and they stay on when the engine is not running (even with the key off the ignition). Brought it to a shop I always go to and they said it's the computer that controls the headlights that has the problem and they weren't able to fix it. I brought it to my dealership and they said there were no short circuits and no relay problem. They only said Etacs - ecu is faulty and I need a new one which they quoted me $975 just for the part itself.
Does anyone know a place to go so i could save a lot or even just a little? I dont like goin to dealerships unless i dont have any other choice.
    « on: August 20, 2014, 06:31 AM »
    August 20, 2014, 08:04 AM #1
    Look online or at the wrecker for an ECU.
    In most cases, its as simple as unplugging the old one, and plugging the new one in, I believe.
      August 20, 2014, 08:07 AM #2
      slipstreamconversion Offline
      • Real Name: Darcy
      • Vehicle: 1997 Toyota Aristo / 1993 Toyota Camry
      • slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.slipstreamconversion is a force to reckon with.
      ^ Sometimes you gotta do a relearn, I am not sure of the process of Mitsubishi, but my car you just had to turn the key to run without turning it on, wait ten minutes for the engine light to flash, then repeat two more times.
      Sorry to hear about the issue, OP.  Kinda sucks that it's so expensy.  Not sure how many wreckers would carry a Lancer DE ecu, but if that doesn't work I'd go to the dealer.
        August 20, 2014, 08:23 AM #3
        That's true, I overlooked the fact of having to relearn.
        I'd say you might be better off finding a used one to save cost. Wuth my car they float around forums for roughly 50 bucks. It may not work, but if it does, it saved you 850 bucks
          August 20, 2014, 08:52 AM #4
          • Real Name: Darcy
          The page at toptierimports.com said:
          Please spread the love before giving reputation to this user again.
          Damnit.
            August 20, 2014, 11:32 AM #5
            WinnipegHID Offline
            • Real Name: Tom
            • WinnipegHID has no influence.
            Are they halogens or HIDs?
            When did the problem start happening?
            Spending $1000 on a computer that would just fix your daytime running lights is insane IMO
            Automotive Lighting Upgrade & Repair Specialists
            Explore & purchase products online SOON: www.winnipeghid.ca
            - Custom Built Headlights
            - HID Projector Retrofitting
            - HID & LED Conversions
            - Custom DRL Setups
            - Headlight Lens Restorations
            and more!...
            885 Redonda Street Unit 9
              August 20, 2014, 11:47 AM #6
              I'd agree, I'd just run without DRL's, pull the fuse or something (if that solved it) to prevent them coming on with the car off.
                August 20, 2014, 01:38 PM #7
                yathots Offline
                • Real Name: James
                They are halogens. It was like this since saturday.
                And yes i know it's insane that's why I'm looking for other options that wouldn't cost me to much just for the drl.
                  August 20, 2014, 01:41 PM #8
                  yathots Offline
                  • Real Name: James
                  Yeah that's what I'm doing right now. But i dont use my car when it starts to get dark out. Can't risk getting pulled over just cuz i dont have my lights on.
                    August 20, 2014, 01:42 PM #9
                    yathots Offline
                    • Real Name: James
                    Thanks for all your suggestions! Will definitely try all of it.
                      August 20, 2014, 03:12 PM #10
                      Streko Offline
                      • Real Name: Paul O.
                      • Vehicle: 2007 Subaru STi
                      • Streko has no influence.
                      Mind if I hijack the thread? I'm also having a small problem with my Daytime Running Lights. My DRL do not seem to come on when I start and drive my car, however they do whenever I remove my key from the ignition and the car goes into the Turbo Cool-down. The DRL setup was an aftermarket installation from the previous owner, but I'm not really able to find who had performed the setup or the name of the kit if one was used.
                      Any thoughts or should I simply take my car into a nearby shop to have a look?
                      I don't drive fast, I fly really low.
                        August 21, 2014, 02:53 PM #11
                        WinnipegHID Offline
                        • Real Name: Tom
                        I'd start by checking any applicable fuses to the DRL circuit. If you can't find any blown fuses then it might be a problem with the actual DRL relay box, I'd check for signs of damage or corrosion of the connections.
                        - Custom DRL Setups
                        and more!...
                          « Reply #11 on: August 21, 2014, 02:53 PM »
