Author Topic: Heated Seat Kits Locally  (Read 3168 times)
December 11, 2014, 11:50 AM #0
cdnturboz Offline
  • Real Name: Steve
  • cdnturboz has no influence.
I got a buddy at work that is looking for a aftermarket heated seat kit for his 07 sentra. He wants to install himself and had called a couple places where they wont sell him the kit as they want to install it too.
My question - are there any places in the city that will sell him juat the kit?
    « on: December 11, 2014, 11:50 AM »
    December 11, 2014, 12:52 PM #1
    Imprzme Offline
    • Vehicle: '16 Legacy 3.6R
    • Reputation Power: 20
    • Imprzme barely matters.Imprzme barely matters.
    I believe Phil @ Fast Toys sells them.  Iirc Visions sells them too.
    Save your breath - you'll need it to inflate your girlfriend
      December 11, 2014, 12:59 PM #2
      jrkoff Offline
      • Real Name: jon
      • jrkoff has no influence.
      heatzz.ca  ?? (they're on wall st)
        December 11, 2014, 06:47 PM #3
        Ron's Upholstery on Regent used to sell the kits for ~$180 a pair iirc
          December 11, 2014, 11:09 PM #4
          cdnturboz Offline
          • Real Name: Steve
          Thanks again guys, ill pass on the info to him.
            December 12, 2014, 12:20 AM #5
            • Reputation Power: 66
            Just ebay or online them. you can get a quality set for under $100 with the switches
              December 13, 2014, 01:56 PM #6
              We have them normally, non instock right now, but 175 a pair.
                December 13, 2014, 08:02 PM #7
                TheCanadian007 Offline
                • Vehicle: 1984 Dodge Omni
                • TheCanadian007 has no influence.
                PartSource has a heated seat kit for ~$85/seat (comes with button and wiring harness) IIRC.
                  December 13, 2014, 10:51 PM #8
                  How much to install them?
                    December 14, 2014, 04:22 PM #9
                    depends a bit on the vehicle but we usually charge 300 per seat (inlcuding the heater of course)
                      December 14, 2014, 07:54 PM #10
                      Installing them isn't very difficult; I did it in my vehicle (albeit with a more home-brew approach) in only an afternoon.
                        December 18, 2014, 10:14 AM #11
                        Install usually isn't cheap because it's generally time consuming. If you have a fair amount of mechanical skill you should be able to do it yourself. Don't get mad at me if you **** everything up though :p
                          December 18, 2014, 10:22 AM #12
                          I got a 26.  Come on down.  Ps I don't drink
                            December 18, 2014, 10:24 AM #13
                            Sure, I'll book you in the next time I have a free few hours..... Looks like that'll be April 2016.
                              December 18, 2014, 10:36 AM #14
                              *2015, car will be done by then, right?! Lol.   No worries, I'm getting a kit at work. And doing most of the work.  Ill get someone to tie it in to the dash properly and route it to the switch nicely
                                December 18, 2014, 02:36 PM #15
                                0-0-7 Offline
                                • Real Name: Colin
                                • Vehicle: del Sol
                                • 0-0-7 has no influence.
                                Anyone know if aftermarket is as good as, better, or worse than a factory setup?
                                  December 18, 2014, 02:43 PM #16
                                  In terms of??? Quality? Heat Output? Life span?
                                  Realistically, in the many years I installed aftermarket ones I can't think of any complaints about heat output and I can't remember every having to replace one, or having one that was DOA.
                                    December 18, 2014, 03:05 PM #17
                                    seanf Offline
                                    • Real Name: Sean
                                    • seanf has no influence.
                                    With the aftermarket ones I find the finish inside the car with the aftermarket switch does not look as nice, if you can tie it all together with the oem switch you probably couldn't tell the difference between an aftermarket and factory heated seat. Do the aftermarket seat heaters heat the back rest as well?
                                      December 18, 2014, 03:13 PM #18
                                      Yes they heat both back and bottom.
                                        December 18, 2014, 04:07 PM #19
                                        most kits do back and bottom.  There are kits that only do the bottom.  Gotta be sure to get the kit you want, as opposed to getting the kit you think you want.
                                          December 18, 2014, 04:16 PM #20
                                          Ive been debating buying a set off ebay just to replace the pooched OEM pads in my Silverado. GM's heater pads like to fail alot and Cost $150 a pair Vs $60 for Aftermarket
                                            December 18, 2014, 04:23 PM #21
                                            Send me make and model via PM.
                                              December 18, 2014, 10:18 PM #22
                                              It's in my signature. Unless your talking about heating pads
                                                « Reply #22 on: December 18, 2014, 10:18 PM »
